NOOOOOO! It STILL leaks!!!!!!&#@*Bison
Last activity 2005-06-20 11:21 PM
9 replies, 7365 views
efaubert1
Posted 2005-06-12 9:11 AM (#26397)
Subject: NOOOOOO! It STILL leaks!!!!!!&#@*Bison
50010025
Well, we went to a show Saturday and everything was great. Came home and parked it till Sunday morning. Of course it rained overnight, so I went out and checked to see how things held up. I opened the door and there is water running down the ceiling seam and the wall. UUGHHHH! Will it ever end, can they actually make a Bison roof not leak? I hope so, or my insurance company, and Gieseke RV in Kokomo aren't going to like me much. LSR was not taxed with fixing the leaks, just the LQ, so I hold no ill will there.
Terri
Posted 2005-06-12 4:10 PM (#26409 - in reply to #26397)
Subject: RE: NOOOOOO! It STILL leaks!!!!!!&#@*Bison
200050010010010025
The dealer didn't get it fixed?  That's awfull.  I hope they can/will fix it.
Reg
Posted 2005-06-12 5:07 PM (#26413 - in reply to #26397)
2000500100252525
Originally written by efaubert1 on 2005-06-12 9:11 AM
bbbbb bb but .. even "reverse engineering" isn't supposed to work that way.
BACKWARDS !
Somebody should have fixed the leaks BEFORE the LQ was re-finished.
{and tested that they had been effectively fixed}
If your first overnight rainstorm - well, you've probably said it all yourself.
Sorry to hear it, this is truely tragic, especially now that the season is getting underway )-:
MIfarmbabe
Posted 2005-06-12 6:04 PM (#26418 - in reply to #26397)
5002525
New trailer(different trailer/brand) shining on the horizon maybe? I would be pissed off and shipping that one out..............to sea.
gabz
Posted 2005-06-13 2:50 PM (#26486 - in reply to #26418)
1000100100100252525
Sorry to hear about your woes...
I've discovered something about mine (not a Bison)... when it is parked, and jacked up at an angle - there's hardly any leaks - but when I have it hooked to the truck and it's near level (unloaded) or level, then I have 4 small leaks at what appears to be the 4 corners of one roof panel. When I first saw the pale rust on the inside, I thought it was a result of condensation - but now, with the insulation in, and the center section of ceiling paneled - I can see that it's more likely leaks - plus, I have witnessed the dripping.
I haven't taken mine in to the dealer just yet... but I will.
My thoughts are that driving over uneven ground, dirt roads, and the slight twisting I witness where the GN is coupled, probably puts the same / similar torque to any and all panels.
Which further leads me to **consider** that perhaps panels that are riveted or bolted (more preferred), with appropriate seals/sealant between, might be a better method of engineering; however - I still think I want a one-piece roof in my "forever" trailer.  I know that bolted panel water tanks suffer far less leaks and are more easily fixed than welded ones...  I'm thinking the same thing about horse trailers - at least you can loosen, apply sealant, and retighten as part of the maintenance, right?
What I am seeing in this trailer and it's line, is a method of manufacture that allows the manufacturer to produce so many "standard" 3H trailers - leaving certain panels as optional configurations - the panel I think is leaking, would be the one that would hold either an a/c unit or roof vent, or as in my case, nothing (I added a roof vent - but in a roof panel farther back - not over the sleeping area.)
So this roof panel has the potential (and, has met that potential I might add), to be a weak point in the roof.
This manufacturing method for THIS model of this brand - is what makes it an affordable trailer, with many great features. (Titan Avalanche 3H GN, fully enclosed with 2 rear doors, no rear tack.)
efaubert1
Posted 2005-06-13 3:28 PM (#26491 - in reply to #26397)
50010025
The RV Dealer and his top fix-it guy came to the house this morning and went to work. They checked everything out and think it may have been coming in around the vent pipe. They re-sealed the vent pipes and the A/C, as well as putting new sealant on the awning assembly at the trailer. Then they hosed her down for 30 minutes and didn't see any leaks. I'm keeping my fingers crossed.
inIndiana
Reg. Feb 2005
Posted 2005-06-20 4:43 AM (#26788 - in reply to #26397)
Wow Ed what rotten luck!
Will the insurance co.
efaubert1
Posted 2005-06-20 8:19 AM (#26793 - in reply to #26397)
50010025
Hey Alice,
They got her fixed and the wife and daugter used it this weekend at the show. All is well for the moment.
Terri
Posted 2005-06-20 12:05 PM (#26799 - in reply to #26793)
200050010010010025
Hope they got it fixed for you.
inIndiana
Reg. Feb 2005
Posted 2005-06-20 11:21 PM (#26837 - in reply to #26397)
Ed,
Don't know what happened with the last post.
If, and pray that it doesn't, happen again I think I would tell to dealership they can buy it back. Then run fast as you can and get a A.S. off the lot. Hope to see you in B.C. soon, high and dry!
