trailer vent question
Last activity 2005-05-16 8:41 PM
2 replies, 4565 views
sonnywrld1
Reg. Mar 2005
Posted 2005-05-16 12:52 PM (#25175)
Subject: trailer vent question
I am in the process of finishing the living quarters in my Kiefer XLA trailer. It has a vent that cranks open, but I want to put a Fantastic Fan in. I removed the million screws the manufacture put in plus the layer of silicone...but it still will not budge. I suppose there is a layer of silicone between the vent and roof. I called Camping World...as they install..they said all they would do is take a razor and keep cutting away on the silicone..not much visible though as it mainly is the vent itself adhering to the roof. The service dept said they get up on the roof to do this...I thought that fiberglass roofs are not strong enough to walk on? The trailer is 5 y/o and has been sitting out in Chicago area winters. Any info on this would be most appreciated. Thanks.
Nancy
Edited by sonnywrld1 2005-05-16 1:00 PM
gabz
Posted 2005-05-16 4:49 PM (#25183 - in reply to #25175)
Subject: RE: trailer vent question
1000100100100252525
Did you remove the vanity or glamor ring from the inside ceiling?
Fiberglass roofs are strong enough - but treat them like the rafters in an attic - that is, keep your weight on a roof beam/support and keep to hands & knees (to spread out your weight).
The RV technician crawled around on the roof of my 1988 Circle J trailer when it was 14 years old - and it's sat out in the Michigan weather probably its entire life.
jackel440
Reg. Apr 2005
Posted 2005-05-16 8:41 PM (#25192 - in reply to #25175)
put a piece of plywood on the roof to spread the wieght if you are concerned about the roof might want to put a blanket down to keep the plywood from scratching the roof
