antenna
Last activity 2005-04-27 10:16 AM
2 replies, 5104 views
choreboy
Posted 2005-04-26 7:17 PM (#24367)
Subject: antenna
I need to install an antenna for small TV in Sundowner trailer. Roof is alumunum. Any suggestions? Thanks
Dawnya
Posted 2005-04-26 9:34 PM (#24376 - in reply to #24367)
Subject: RE: antenna
1001001001002525
Glad you brought this up, I do too.
Mine is aluminum also AND the roof is already insulated.  Will it be a complete PIA?!?!
PaintPony
Posted 2005-04-27 10:16 AM (#24389 - in reply to #24367)
A friend of mine went the "easy" route. She has a set of rabbit ears that unscrew for travel that are mounted just outside of her escape door. She screws the "ears" in at the show and usually gets as good, if not better reception than I do with my roof-mounted antenna. She ran the wire from the tv mount along the wall, through the top corner of the door frame to the horse area and out the top of the escape door. There is a wire in the horse area but she's got it attached at the very top of the wall.
