Rain gutters, drip rail, etc.
Last activity 2005-04-27 7:57 PM
8 replies, 7487 views
NoSpam
Reg. Feb 2005
Posted 2005-04-26 4:49 PM (#24354)
Subject: Rain gutters, drip rail, etc.
Hi,
I would like to install some sort of drip rail or gutter system around my trailer to protect my windows and doors.  Any suggestions on materials or sources?  So far I like RainKap (http://www.rainkap.com/) and insert drip rail (http://www.all-rite.com/insertdriprails.html) - but they are both fairly expensive.
The cheapest/best local solution I could come up with is installing a simple J-channel trim underneath the existing vinyl drip rail.  That's if I can figure out how to get caulking in where it's needed.
Any suggestions??
Happy Trails,
Michelle
Terri
Posted 2005-04-26 5:09 PM (#24357 - in reply to #24354)
Subject: RE: Rain gutters, drip rail, etc.
200050010010010025
I really like the look of those rainkaps.  But your right.  It is expensive.  I've been looking for a similar solution.
NoSpam
Reg. Feb 2005
Posted 2005-04-26 5:54 PM (#24362 - in reply to #24357)
Yeah, I like that stuff too, but wonder how it would hold up in snow and ice.  Wouldn't be too pricey if I just put it around the LQ siding...
Happy Trails,
Michelle
NoSpam
Reg. Feb 2005
Posted 2005-04-27 10:25 AM (#24390 - in reply to #24362)
Quick update - I decided no on the Dripkap, because unless I am parked on a level surface (that doesn't happen often...) the rain will still roll off the cap and roll down the side of my trailer.  Or if the wind is blowing (which it always does here) it will blow the falling water right onto my trailer.  Gutters appear to be the better way to move water.  I can fabricate fairly deep pieces out of L shaped aluminum and install them directly below existing vinyl insert trim...  Not as cool as the prefab one piece trim, but loads cheaper and very functional.
Happy Trails,
Michelle
Rander
Reg. Mar 2005
Posted 2005-04-27 3:46 PM (#24405 - in reply to #24354)
Michelle
You might want to check out the link below. It is an inexpensive elegant solution to the gutter problem for an RV that might work for you.
http://www.bbrv.dreamstation.com/gutter.html
NoSpam
Reg. Feb 2005
Posted 2005-04-27 5:11 PM (#24410 - in reply to #24405)
Thanks - I looked everywhere for that vinyl J bead locally and can't find any!  All I can find is a horrid lightweight aluminum version.  A mirror/glass place said they could order vinyl in for me, though.
I ended up finding some aluminum bullnose material today which I will try first.  I attached a picture of it.  It's in the carpet section of Home Depot.  It's sort of a right angle, but one of the angles has a nice little trough in it.  I think it can go right under the vinyl insert trim...  It's another one of those affordable items - I think $8 for 12'.  Its about 1.25" by 1.25".
Happy Trails,
Michelle
Edited by NoSpam 2005-04-27 5:13 PM
Terri
Posted 2005-04-27 7:06 PM (#24413 - in reply to #24410)
200050010010010025
how did you attatch the file?
NoSpam
Reg. Feb 2005
Posted 2005-04-27 7:26 PM (#24415 - in reply to #24413)
When you post a message, there is a checkbox right under where you type your text - it says "Attach a file to this thread after posting", check that box and after you click submit you can attach a file to your post.  Easy peasy, lemon squeezie!
Happy Trails,
Michelle
Terri
Posted 2005-04-27 7:57 PM (#24418 - in reply to #24415)
200050010010010025
Thank you.  I'm gonna have to try that.
