Tires cracks
Last activity 2005-04-21 7:31 PM
4 replies, 5955 views
soho
Posted 2005-04-21 10:57 AM (#24109)
Subject: Tires cracks
I just noticed today on all 4 horsetrailer tires a very fine crack in the sidewalls going all around.
the cracks is probably just 1/64 or 1/32 " thick. the tires are about 8 years old a not alot driven.
profile is still very good.
Is there any concern about safety ?
thanks for any information.
Terri
Posted 2005-04-21 12:34 PM (#24114 - in reply to #24109)
Subject: RE: Tires cracks
200050010010010025
Thats dry rot from exposure.  It weakens the tire and can cause it to blow.  I lost a tire a few weeks ago and when I took it in (it looked new) the dealer ran the numbers off the side and found that the tires were made 7 years ago.  They were the original tires.   He said that trailer tires rarely run out of tred (unless you haul a LOT) but fail due to age.  I bought  a new tire and before I go to NM I will be replacing the others.
Texas Butch
Posted 2005-04-21 12:45 PM (#24117 - in reply to #24109)
After a couple of blow outs on my old bumper pull trailer, I invested in tire covers.  Have them on both my trailers now.  Hope the covers will help delay the tires from cracking.
maccwall
Reg. May 2004
Posted 2005-04-21 12:56 PM (#24119 - in reply to #24117)
500
I would definately have them replaced. Ever seen what blown trailer tire can do to a fender or worse to a person airing up a low tire? I was always told that trailer tires should be replaced every 3 to 4 years regardless of tread wear. That might be extreme considering the cost of tires, but as a safty issue to my animals it's worth it to me.
Safe Riding,
Todd
chadsalt
Posted 2005-04-21 7:31 PM (#24134 - in reply to #24109)
1000100100100100
Originally written by soho on 2005-04-21 11:57 AM
yes that is an extreme saftey issue.  any tire that old with visable cracks can fail at any time.  most tire manuf. recommend replacing tires at 3 or 4 years whatever the milage.  if you prowl the rv boards some people go 6 or 7, tire covers will help prolong a tires life. for the $500 +/- a new set would cost verses what a blow out can cost in lost time, damaged equipment, etc i believe the choice should be obvious.
