right lead
Last activity 2005-04-14 4:28 PM
3 replies, 4183 views
Reg. Dec 1899
Posted 2005-04-13 12:01 AM (#23770)
Subject: right lead
I have a 5 yr old paint mare she is a joy to ride however there is one problem. She leads to the left very well, but her right lead is rough. Once I get her on the correct lead she is fine, but it takes a while to get her there. Any suggestions?
rotag
Reg. Oct 2004
Posted 2005-04-13 5:01 AM (#23776 - in reply to #23770)
Subject: RE: right lead
We do circles starting small in both directions. As the leads get smoother and lower we will begin to two track out. Then we begin working on figure 8s at first it is challaging till you get it right. Then it gets boring as you prefect it.
Edited by rotag 2005-04-13 5:03 AM
huntseat
Posted 2005-04-13 9:07 AM (#23790 - in reply to #23770)
1000500100100100100252525
Right leads are harder for almost every horse. Horse are left handed. You really should focus on the flexibility of her right side and work on her moving away from your cues. Two tracking would be nice but at two most horsesa ren't strong enough in their core to hold everything together. Two tracking is a more advanced move. You might try cueing her in corners, sitting down, driving her deep into the rail/corner and asking as you near the fence. You want to be at a 30 degree angle when you head into the rail. Just as she lifts her inside shoulder to "track away" from the rail, cue! This lifting of her hsoulder should allow her to drive more easily with her inside hip. SOMetimes our babies have problems engaging their shoulders/hips because they lack the muscle strength to control their bodies plus the extra weight of a rider. Keep working her and she'll get stronger!
Edited by huntseat 2005-04-13 9:08 AM
MIfarmbabe
Posted 2005-04-14 4:28 PM (#23851 - in reply to #23770)
5002525
Also try doing some transition changes with her from the trot to canter and vice versa. Once she is cantering don't keep cantering her and cantering her, she'll grow bored. Come down to a trot, get her collected then cue for the canter again. Don't rule out a physical problem either. If she is really that bad to cue on the right lead, look into having her checked by your veterinarian.
