subfloor construction?
Last activity 2005-04-05 1:45 PM
4 replies, 6207 views
NoSpam
Reg. Feb 2005
Posted 2005-04-05 9:21 AM (#23444)
Subject: subfloor construction?
My fixer-upper currently has a particle board sheet installed as the LQ subfloor.  It was installed by the guy who tried to fix the trailer before he gave up and sold it to me. :-)  Is this OK to leave in, or should I pull it out and install plywood?  I thought plywood (maybe 3/4 inch?) with the underside well coated with polyurethane might last the longest.
Then board insulation, then OSB?  Any idea what thickness I need for the top layer of wood?  Eventually it will be covered with vinyl flooring with a rug on top.
Happy Trails,
Michelle
efaubert1
Posted 2005-04-05 9:29 AM (#23445 - in reply to #23444)
Subject: RE: subfloor construction?
50010025
Particle board does not handle moisture as well as 3/4" sturdy floor plywood you can get from Lowes, Menards, or Home depot. So I would definetly replace the particle board, it will save you labor in the longrun in my experience.
maccwall
Reg. May 2004
Posted 2005-04-05 12:01 PM (#23457 - in reply to #23445)
500
I definately agree with efaubert1. I'd replace the particle board and replace it with 3/4" plywood. I would consider getting the treated plywood and coating the bottom with polyurathane or even the sprayon bedliner like they put in truck beds. You can buy it in the spray can at Autozone or Oreilly's and I think Napa. I'd also coat the edges of the sheet you put in.
As far as insulation, I used 1/2" foam insulation and 3/8" OSB for my flooring (you can see it in my pics in my signature) but since your using plywood for the floor to begin with I really don't think it would be nessesary to insulate it since the wood would be a good insulator itself, but that's totally up to you.
Hope this helps.
Safe Riding,
Todd
MIfarmbabe
Posted 2005-04-05 1:34 PM (#23461 - in reply to #23444)
5002525
Plywood is pretty inexpensive right now, at least at the Home Depot. Off hurricane season right now maybe?
NoSpam
Reg. Feb 2005
Posted 2005-04-05 1:45 PM (#23464 - in reply to #23444)
Thanks guys!  I hate particle board, so I started ripping it out as soon as I read your posts.  The smaller piece is now out, it is glued with construction adhesive to the metal beams below so it's kinda hard to get out...  Picture attached.
Are there any easy ways to get construction adhesive to delaminate from particle board?  I had to use a jig saw, then crowbar, then chisel, then sharp chisel/knife.  Thought about scoring the next one with a skill saw set at the proper depth.  That might greatly reduce the amount of chiseling.
Ufff.
Happy Trails,
Michelle
