NEED WEIGHT CHART FOR ALUMINUM BP'S!
Last activity 2005-04-02 8:11 AM
1 replies, 5548 views
willow
Reg. Apr 2005
Posted 2005-04-01 9:03 PM (#23334)
Subject: NEED WEIGHT CHART FOR ALUMINUM BP'S!
I need to compare total empty weight for different aluminum bumper pull trailers.  Does anyone know of a website? Thanks
Reg
Posted 2005-04-02 8:11 AM (#23338 - in reply to #23334)
Subject: RE: NEED WEIGHT CHART FOR ALUMINUM BP'S!
2000500100252525
Hi and Welcome.
We've kicked around the whole relative prices, used values, weights and other specs questions several times. The answer seems to be that some manufacturers provide some information, others provide very little and nobody seems to draw it all together into any sort of comparative sets.
If you have your choices narrowed down to two or three the best way may be to ask about them individually. For a given size bumperpull aluminum trailer I doubt that there is much variation in weights anyway. Personally I don't think I would make a purchase decision based on weight.
Here's ONE data point you might be able to use: '04 2 horse straight load bumper pull 7ft wide 7ft 6in inside height Jamco with DR/tack room, rear(hefty) ramp, reinforced "escape" doors with bar latches - 2780 lbs, GVWR 7,000 lbs.
Jamcos are definitely on the heavy side of average.
Edited by Reg 2005-04-02 9:44 AM
