Replacing floor in horse trailer
Last activity 2021-07-08 2:44 PM
5 replies, 3228 views
Safehorses
Reg. Jun 2021
Posted 2021-06-26 2:27 PM (#173987)
Subject: Replacing floor in horse trailer
Hi everyone. I need to replace the wood floor boards in my older horse trailer. Should I use pressure treated wood?
Thank you.
Brenda
cajunmuleman
Reg. Oct 2011
Posted 2021-06-26 6:11 PM (#173988 - in reply to #173987)
Subject: RE: Replacing floor in horse trailer
I know of no reason not to
hgut
Posted 2021-06-27 5:30 AM (#173989 - in reply to #173987)
we used southern yellow pine some really strong stuff, google the facts, we oil stained it first
Posted 2021-06-28 6:32 AM (#173993 - in reply to #173987)
Depends on what was originally installed. If it was treated wood, you're good to go with treated wood. Be aware treated wood is usually pine, it's weaker than oak. If the original wood was OAK, then the supports may be too wide for pine. Then replace with similar oak boards or increase the supporting structure. Oak boards can be sourced from a pallet builder. Just search for a local outfit to you.
I treated my oak boards with wood preservative after they were cut to fit the floor but, prior being installed in trailer.
calamityj
Reg. Jun 2005
Posted 2021-06-28 7:41 AM (#173994 - in reply to #173987)
500100252525
Very important to check support of frame underneath before you replace the wood! You may need to weld some more braces under it if you have rust.... use TREATED LUMBER ALWAYS.... or Rumber with good frame support.
HOUSE
Reg. Oct 2008
Posted 2021-07-08 2:44 PM (#174020 - in reply to #173987)
I dont recommend using pressure treated to replace your floor, the reason behind it is  that if do a quick search you will see that you cannot use standard metal fasteners  with pressure treated, the reason for this is that non zinc coated steel reacts with metal and creats corrosion, ie the pressure treated wood you use cannot touch the metal of your trailer, or it will corrode even faster, so you need to use special fastners and isolate it with plastic or some other inert barrier.
