Air conditioner not working
Last activity 2021-12-11 5:51 AM
6 replies, 6785 views
always amazed
Reg. Feb 2008
Posted 2021-05-05 5:44 AM (#173677)
Subject: Air conditioner not working
I have a 99 sundowner with central heat and air. It has a wall thermostat. I tried to turn it on this year and nothing happened. The wall thermostat lights up with functions but air doesn't come on. How do I trouble shoot the problem? Does that automatically mean my air conditioner is bad or something with the wall turn on. It doesn't even try to kick on???ont-family:Arial; font-size:12px; color:#000000">
RTSmith
Posted 2021-05-05 7:39 AM (#173678 - in reply to #173677)
Subject: RE: Air conditioner not working
The thermostat itself runs off of 12V (batteries/converter). The rooftop unit is powered by the 110V shore power cord. It sounds like your 110 isn't hot. Is your microwave working? Follow the cord for a good connection, and then check breakers (in the nose of the trailer) and maybe even the breaker that powers the plug the trailer is actually plugged into.
RTSmith
Posted 2021-05-05 7:40 AM (#173679 - in reply to #173677)
If the roof unit buzzes, but doesn't run that's another problem. Sitting can allow mouse nests, and other things to need a good cleaning and lubing up top. Dirt dobbers are famous in there too.
martiscore
Reg. Jun 2021
Posted 2021-06-14 9:18 AM (#173762 - in reply to #173677)
I have the same problem. I've tried the aforementioned solution, but it didn't help - ac still don't work.
Neironwik
Reg. Apr 2021
Posted 2021-09-07 9:25 AM (#183720 - in reply to #173677)
always amazed - 2021-05-05 5:44 AM
Well, find info about it on Google, that's it!
Mistrales
Reg. Nov 2021
Posted 2021-12-11 5:14 AM (#185121 - in reply to #173677)
I have a question, how often did you fill-up the air conditioner?
cajunmuleman
Reg. Oct 2011
Posted 2021-12-11 5:51 AM (#185122 - in reply to #173677)
Fill up with what? If you are speaking of refrigerant it only needs to be filled if it has a leak and filling it up is almost pointless unless you fix the leak because it will leak out again. The refrigerant never goes bad.
