featherlite horse trailer ramp heavy
Last activity 2021-05-02 6:37 PM
4 replies, 5445 views
jgale58
Reg. Apr 2021
Posted 2021-04-22 6:07 PM (#173644)
Subject: featherlite horse trailer ramp heavy
I purchased a 2007 2 horse straight load Featherlite horse trailer, and discovered that the ramp is extremely heavy to lift. Is it supposed to be this way?
RTSmith
Posted 2021-04-26 7:09 AM (#173659 - in reply to #173644)
Subject: RE: featherlite horse trailer ramp heavy
500100100100
Not particularly- but the springs are 15 years old. And sometimes the hinges can bind with the center pin. Unfortunately, none of those are particularly easy to correct. You might try a really good cleaning of the hinge area to make sure no crud is in there. And then a penetrating oil on the shaft where it goes through the hinge ferrules.
calamityj
Reg. Jun 2005
Posted 2021-04-28 9:02 AM (#173665 - in reply to #173644)
500100252525
jgale58 - 2021-04-22 6:07 PM I purchased a 2007 2 horse straight load Featherlite horse trailer, and discovered that the ramp is extremely heavy to lift. Is it supposed to be this way?
You can re-work the springs or spring helpers.... we just did on our older weekender straight load we use for short hauls... be sure everything is in workable shape, try to adjust the springs and lube it up.. I will try to post pics...
jgale58
Reg. Apr 2021
Posted 2021-04-30 10:33 AM (#173667 - in reply to #173665)
How do you rework the springs? Should I replace the springs?
calamityj
Reg. Jun 2005
Posted 2021-05-02 6:37 PM (#173670 - in reply to #173644)
500100252525
Featherlite.com
