Platinum Trailer
Last activity 2021-04-15 1:28 AM
3 replies, 2908 views
gionne
Reg. Nov 2020
Posted 2021-04-13 11:07 AM (#173618)
Subject: Platinum Trailer
I recently purchased a 2015 Platinum Horse trailer - I noticed it is wet under the rubber mats, so I pulled them up and open windows and dried the floor completely. I put the mats back down after a week I went and pulled the mats up and it is wet again. Any suggestions as to why this is happening and how to fix?
Thank you.
BJMCFW
Reg. Jan 2021
Posted 2021-04-13 2:14 PM (#173619 - in reply to #173618)
Subject: RE: Platinum Trailer
Not 100% sure. All could depend on your location, outside temps and weather conditions.
Here in North Texas if we do the same process and it is humid outside we will have moisture under ours after a few days.
gionne
Reg. Nov 2020
Posted 2021-04-14 2:41 PM (#173622 - in reply to #173619)
Thank you for your reply. I a live in Wisconsin. So is this something to worry about?
DLR
Reg. Jul 2004
Posted 2021-04-15 1:28 AM (#173623 - in reply to #173618)
Are there drain holes in the floor?  If not drill some - make sure you do not drill thru  a cross member.  We also keep a layer of wood shavings on the floor which helps. Minor leaks in the horse area is not uncommon.   We're in Minnesota.
