Stall lights and outside flood light not working
Last activity 2022-05-10 8:46 AM
4 replies, 5429 views
Ljk
Reg. Dec 2020
Posted 2020-12-14 10:37 AM (#173391)
Subject: Stall lights and outside flood light not working
I am plugged into shore lighting from trailer to a house, not to a pickup as I am currently living in it. All the interior lights and outlets work and a few days ago the stall lights and outside flood light worked. Now the stall lights and flood are not working. Checked the fuses and they seem to be good. Any ideas out there?
Ljk
Reg. Dec 2020
Posted 2020-12-14 11:15 AM (#173392 - in reply to #173391)
Subject: RE: Stall lights and outside flood light not working
Figured it out. Battery in the breakaway died due to not charging off the pickup. Once I plugged into the pickup, lights work.
peterhend
Reg. Aug 2021
Posted 2021-08-12 12:52 PM (#181279 - in reply to #173391)
I've seen threads that can definitely help you.
peterhend
Reg. Aug 2021
Posted 2021-08-19 4:33 PM (#181972 - in reply to #181279)
You can just put an LED light bulb there. The process of replacing the lamp is quite complicated. If you do not know how to do it correctly, it is best to seek professional help. I recently decided to install flag pole lights . I thought it would be easy, but it turned out to be much more complicated. I spent a lot of time and decided to seek help from specialists. Moreover, I had some problems and I am glad that I asked for help. My neighbor once decided to do the same thing on his own and a fire almost happened...
___________________________________________________
https://www.amazon.com/Flagpole-Energy-Battery-Illumunation-Vont/dp/...
likerasd
Reg. Apr 2022
Posted 2022-05-10 8:46 AM (#185296 - in reply to #173391)
Inspect the wiring for physical integrity. Check the absence of breaks, burnt insulation, and kinks in the cable. Check the housing of the device and the LED matrix for mechanical damage (deformations, chips, cracks).
