leaky pipe connected to black water tank
Last activity 2022-02-14 7:07 AM
2 replies, 4560 views
tirebiter
Reg. Oct 2009
Posted 2020-08-05 1:05 PM (#173178)
Subject: leaky pipe connected to black water tank
Right where the tank has its spout to connect to the 3' plastic piping there is a leak at the seam of the pipe.  I tried using flex seal but it did'nt work (maybe because it was still wet, even though supposedly you can apply when wet).  anyway, looking for any tips to get this fixed.  Thanks!
horsey1
Reg. Dec 2004
Posted 2021-05-04 10:29 AM (#173676 - in reply to #173178)
Subject: RE: leaky pipe connected to black water tank
Plumbing connections are a chemical weld. Often referred to as glue, but technically a weld. You may try some sealant, but generally it takes disassembly and proper reassembly.
hgut
Posted 2022-02-14 7:07 AM (#185160 - in reply to #173178)
I remember when this forum was the best, now just a bunch of spamsters
