LED Tail Light Replacement
Last activity 2022-07-01 4:12 PM
8 replies, 9015 views
Lazy M
Reg. Feb 2005
Posted 2020-06-28 8:43 PM (#173125)
Subject: LED Tail Light Replacement
 So one of my tail lights on my 2002 Elite trailer is not working.   i thought this may be a good time to replace them with LED lights.
I could take it to shop, but if it was possible.......I would try to replace them myself.
Hmmm
If i could manage this job, would I need load resisters?
Words of wisdom?
Thanks
Joan
cajunmuleman
Reg. Oct 2011
Posted 2020-06-29 2:42 AM (#173127 - in reply to #173125)
Subject: RE: LED Tail Light Replacement
I replaced the lights on my truck and old trailer with LEDs and had to add the resistors, which took care of the problems
goldenbear2001
Reg. May 2014
Posted 2020-06-29 4:29 AM (#173128 - in reply to #173125)
www.etrailer.com has a wide assortment of items LED lights to choose from. The also have an extensive knowledge base.
DLR
Reg. Jul 2004
Posted 2020-06-29 4:36 AM (#173129 - in reply to #173125)
When I converted the lights on my truck to LED, I needed to add the resisters.  I have done my LQ horse trailer and my 4-horse trailers to LED and did not need resisters.  Both have worked well for past 3 years.
If you do some research, you can find LED lights with the same holds for mounting that you currently have.   I found my lights thru Redneck Trailer.
Just be aware LED cost considerable more than old style lights.
Posted 2020-06-29 11:53 AM (#173131 - in reply to #173125)
Depends on your truck... 2001 Chevy 3500 Changed to LED, no other change required
SilentWorker
Reg. Oct 2021
Posted 2021-10-28 3:41 PM (#184973 - in reply to #173125)
I have a friend who makes a living with someone who serves large enterprises where the main lighting equipment is LED strip. According to him, the great importance and maintainability of LED strips depend on the manufacturer.
tysoncortwright9
Reg. May 2022
Posted 2022-05-04 9:10 AM (#185290 - in reply to #173125)
Yes, you would definitely need resistors. I've been in a similar situation as yours, and after installing them, it's like a stone falls off my heart.
tysoncortwright9
Reg. May 2022
Posted 2022-05-06 4:40 PM (#185294 - in reply to #185290)
tysoncortwright9 - 2022-05-04 9:10 AM
When I'm dealing with that kind of matter, usually I reach here for help https://lightingandsupplies.com/larson-electronics/. It's a well-known distributor company that engages in small and bigger projects. I tried a couple of times replacing LEDs by myself, but unfortunately, I ruined them. Since then, I'm leaving it for more dexterous specialists to do it.
camminskireal
Reg. Jul 2022
Posted 2022-07-01 4:12 PM (#185334 - in reply to #173125)
Thanks for the information.
