Repairing the trailer walls
Last activity 2019-12-04 6:52 PM
3 replies, 4289 views
dperme
Reg. Dec 2019
Posted 2019-12-01 7:33 AM (#172862)
Subject: Repairing the trailer walls
I have some rotten plywood on my trailer from a leaking window seal, the horse kicked the butt bar mount off, thus I discovered the rot. I am planning to buy some H channel aluminum extrusion to put along the middle of the existing lower wall and replace the top of the wall. Rough dimensions of the plywood repair panel will be 7'X3', probably go with 3/4 inch thick material. Question, what do I apply on the exterior surface of the plywood? Paint would protect but look pretty cheesy. Is there some type of adhesive material in that size that would go on that? The trailer is mostly aluminium.
Posted 2019-12-01 10:14 AM (#172863 - in reply to #172862)
Subject: RE: Repairing the trailer walls
Rubber mat. Used conveyor belting is tough and durable. Check with an industrial supply house for new material. 7x4 feet might even be a scrap to be had inexpensively or free.
Posted 2019-12-02 9:01 AM (#172864 - in reply to #172862)
Try some 3/4  baltic birch plwood covered with the rubber matting. It adds a geat deal of stength and durability
galarian
Reg. Dec 2019
Posted 2019-12-04 6:52 PM (#172874 - in reply to #172863)
I'm currently on a search for new repair materials that I could use. I need to make an estimate as well.
