Drop down windows leaking running into latches and holds the water
Last activity 2019-11-12 12:16 PM
0 replies, 3058 views
toby&chance
Reg. Jan 2011
Posted 2019-11-12 12:16 PM (#172831)
Subject: Drop down windows leaking running into latches and holds the water
My drop down windows are leaking i have 6 and all are..  Seems like plenty of rubber 3/4" thick but could use a replacing possibly, water runs in the latches on the windows and stays there till i put windows down very little water if any is running inside horse trailer.  Windows are more on the exterior not flush with the side of the trailer.  I am not sure what to do one window actually has flashing above to avoid running into windows but it still gets in there.  I need to get this fixed before my windows bust and freeze trailer is inside heated now but has anyone else run into this problem??  Its wierd if all 6 windows need resealing with new rubber which does not look warn.   thank u in advance
