Tires wearing funny way
Last activity 2019-10-16 3:36 PM
5 replies, 3316 views
FFFran
Reg. Mar 2013
Posted 2019-10-14 9:35 AM (#172769)
Subject: Tires wearing funny way
 I noticed that my front driver tire and my rear passenger tire are both wearing significantly on the inside. The other tires have even wear. It doesn't make sense. They are on opposite axles. What would cause this?  Need to replace tires  anyway so I would like to make sure that I am not putting good money to waste,
Thanks
Jbsny
Reg. Apr 2004
Posted 2019-10-14 4:45 PM (#172770 - in reply to #172769)
Subject: RE: Tires wearing funny way
10010010025
 They might need to be aligned.   I used a semi truck repair place to check mine before I got new tires.   There is information online about how to look at your tires to see if your  axles need to be aligned.
Jbsny
Reg. Apr 2004
Posted 2019-10-15 5:01 AM (#172771 - in reply to #172770)
10010010025
 Oops, sorry, thought you meant tires on your trailer, not truck, duh!!!
FFFran
Reg. Mar 2013
Posted 2019-10-15 7:22 AM (#172772 - in reply to #172769)
I did mean tires on my trailer.  If they need to be aligned, wouldn't it be on both axles?
HOUSE
Reg. Oct 2008
Posted 2019-10-15 12:11 PM (#172776 - in reply to #172769)
 sounds like you have bent axles, they can be straigtend depending on the person doing it it may work it may not, I typically just rotate the tires around the trailer to extend life as much as possible, unless it you are putting tons of miles on it you will probably be fine.
Jbsny
Reg. Apr 2004
Posted 2019-10-16 3:36 PM (#172778 - in reply to #172769)
10010010025
I'd check with a semi repair facility,If you don't have a horse trailer repair business near by, they align semi axles.  They might be able to suggest a course of action if you need help.  There are you tubes that talk about alignment which could be your first stop.  A couple you tubes showed how to use a 2x4 to check the tire positions and if the are out of whack.
