Trailer "lift" kit
Last activity 2019-07-08 11:10 PM
6 replies, 4756 views
BRcwgrl81
Posted 2019-04-17 7:19 AM (#172330)
Subject: Trailer "lift" kit
 Can anyone tell me where i'd buy a "lift" kit for my trailer?  The truck and trailer, when connected are not level.  My trailer sits back.  I need to block the axel I was told.  My husband wants to do this himself, but I have no idea where i'd buy what is needed.  Can annyone help?
Thanks!
Edited by BRcwgrl81 2019-04-17 7:20 AM
cajunmuleman
Reg. Oct 2011
Posted 2019-04-18 2:39 AM (#172332 - in reply to #172330)
Subject: RE: Trailer "lift" kit
I don’t know of any “kits”. I had a local trailer / welding shop do this several years ago and they used heavy gauge square tubing between the axle and frame.
jdzaharia
Reg. Apr 2006
Posted 2019-04-18 9:17 AM (#172334 - in reply to #172330)
1001001001002525
Same as above here.  On my steel-frame, torsion-axle trailer, it was as simple as 4 pieces of 2.5-inch square tube.  My local repair shop cut the axles off the frame and welded the tube back between the axles and frame.  Other trailers may be more complicated if it has leaf spring axles or an aluminum frame.  If your husband is capable of doing the work, he's capable of figuring out what materials he needs.
Posted 2019-04-18 5:42 PM (#172335 - in reply to #172330)
All depends on "YOUR" trailer. Some trailers have the axles welded and some axles are bolted.
With my Sundowner, the axles were bolted on. 3 inch x 1/4 wall square tubing pieces were sandwiched between the axles and frame. New longer grade 8 bolts and nuts hold it all together.
Has worked well for thousands of miles.
DLR
Reg. Jul 2004
Posted 2019-04-19 5:14 AM (#172337 - in reply to #172330)
Blocked my 4 Star same as above 1,000s of miles ago and has worked fine.
Posted 2019-05-23 7:46 PM (#172405 - in reply to #172330)
BRcwgrl81 - 2019-04-17 10:19 AM  Can anyone tell me where i'd buy a "lift" kit for my trailer?  The truck and trailer, when connected are not level.  My trailer sits back.  I need to block the axel I was told.  My husband wants to do this himself, but I have no idea where i'd buy what is needed.  Can annyone help?
Thanks!
If he does NOT get those axles mounted square...you'll shred your tires BIGLY...
nomatt
Reg. Jan 2018
Posted 2019-07-08 11:10 PM (#172526 - in reply to #172330)
What they said. It is either you block the trailer or get a flatbed. I had a bumper pull trailer. I just bought a drop hitch at 4wheelonline| trailer hitches because my truck sits higher than the trailer.
Edited by nomatt 2019-07-08 11:11 PM
