Circle J slide out issue
Last activity 2018-10-27 8:39 AM
3 replies, 4304 views
Christine
Reg. Jul 2007
Posted 2018-10-24 3:44 PM (#171984)
Subject: Circle J slide out issue
I have a 2007 Circle J Mirage LQ with a 6 ft. slide out. Have traveled all over the country and never had a problem until now. Can't bring the slide in and cannot locate the manual override. Have taken the carpet off the inside face of the slide and it's screwed in and stapled to the plywood floor so not easily accessible to the motor. Has anyone else encountered this problem and how did you solve it?I have reached out to the new owners of Circle J, Big Tex, and they can't help and the dealer I purchased from is also no longer in business.
horsey1
Reg. Dec 2004
Posted 2018-10-26 6:39 AM (#171987 - in reply to #171984)
Subject: RE: Circle J slide out issue
Not familiar with the Circle J. Sorry. But- not all slides have a manual override. And those that do it only works for certain issues mainly a motor not working or power issue. Gear/cable/chain/gear issues normally will need repair before it moves.
brokenboot
Posted 2018-10-26 3:06 PM (#171989 - in reply to #171987)
I don't have a Circle J and am not familiar with how their slides work.  However, we were camping once and lost power to the slide motor on our Trails West.  We'd just unloaded the horses and couldn't get the slide to go out.  I located the motor and override lever underneath the slideout.  But switching a lever, I was able to move the slideout without the use of the electric motor and found that a socket and rachet fit perfectly and gave enough leverage to easily move the slideout.  Mine turned out to be a short and we were lucky enough to have a camper offer his electronic expertise to find and fix the broken wire.  But I was relieved to find I could move the slide in or out without electricity if need be.  Good luck with yours!
beeoerdog
Reg. Jan 2014
Posted 2018-10-27 8:39 AM (#171991 - in reply to #171984)
10010010010025
can you hear any noises at all? Check underneath the slide and see if the rollers are on solid material...I have seen the rollers poke thru the plywood making it impossible for the slide to move
