Swapping load G rims for load E rims.
Last activity 2018-10-12 4:43 AM
3 replies, 4259 views
Socks
Reg. Apr 2015
Posted 2018-10-04 7:48 AM (#171916)
Subject: Swapping load G rims for load E rims.
 Do the 8 lug 16” trailer rims for the load G 110 psi tires have the same size lug holes and pattern as the 8 lug 16” trailer rims for the load E  65 psi tires.  Need to pull new to us trailer 700 miles home and it has ten year old load E tires. Can take along and swap our current load G tires if the rims will bolt up.  Both are from/for Sundowner trailers.
Edited by Socks 2018-10-04 7:52 AM
RTSmith
Posted 2018-10-04 11:17 AM (#171918 - in reply to #171916)
Subject: RE: Swapping load G rims for load E rims.
The bolt pattern on both is a 8x6.5" pattern. The lug holes are likely the same. Thus I don't believe you'll have an issue. There may be a difference in stud diameter, depending on axle size, but the wheels should change back & forth. 8K axles have larger studs than 7K as I recall.
HOUSE
Reg. Oct 2008
Posted 2018-10-09 10:27 PM (#171954 - in reply to #171916)
 the lugs may match up but the stud size may be bigger, if you are buying new wheels i would really urge you to step up to 17.5 inch wheels, the tires are worlds better and easier to find and often times cheaper than 16 inch G rated tires
calamityj
Reg. Jun 2005
Posted 2018-10-12 4:43 AM (#171960 - in reply to #171918)
500100252525
Oh my..I would not drive an hour from home on ten year old tires.. Hope your others fit to go...Good luck to you.
Edited by calamityj 2018-10-12 4:45 AM
