Fixing up old Logan Slant Load: What's this switch do???
Last activity 2018-08-05 8:33 AM
3 replies, 5326 views
eldoradobill
Reg. Aug 2018
Posted 2018-08-04 9:55 AM (#171774)
Subject: Fixing up old Logan Slant Load: What's this switch do???
Hi all - we've had this Logan Coach slant load for about 25 years. It's been stored outside and neglected. I rarely ever see it. It's my wife's thing.
Anyway, we brought it home to clean it up and give it the once over. I'm pretty handy and have cleaned it up and fixed it up to where, dang if it don't look pretty now. :-) I traced an electrical problem to the six-prong plug and will have a replacement here to install on Sunday.
In the meantime, I ran a test off of a 12 volt battery direct to the individual (currently) exposed wires and confirmed brake lights and running lights work.
Neither exterior (left rear/right front) loading lights work, but confirmed the bulbs are good. The interior lights do not work as well.
I'm guessing these are powered by the battery (dead as dead can be) located in the tack room. Is that correct?
Also, there is a toggle switch located at the rear left (driver's side). What is this switch for?
Thanks for any help.
Bill
beeoerdog
Reg. Jan 2014
Posted 2018-08-04 12:47 PM (#171775 - in reply to #171774)
Subject: RE: Fixing up old Logan Slant Load: What's this switch do???
10010010010025
The battery in the tack room is probably just for the brakes...via breakaway switch connected via cable connected to the tow vehicle. Other lights are probably powered by way of pin on the trailer connector connected to vehicle battery...and will only work when plugged in....sometimes the tow vehicle needs to have key in on position
Posted 2018-08-04 1:31 PM (#171776 - in reply to #171774)
eldoradobill - 2018-08-04 12:55 PM Hi all - we've had this Logan Coach slant load for about 25 years. It's been stored outside and neglected. I rarely ever see it. It's my wife's thing. Anyway, we brought it home to clean it up and give it the once over. I'm pretty handy and have cleaned it up and fixed it up to where, dang if it don't look pretty now. :-) I traced an electrical problem to the six-prong plug and will have a replacement here to install on Sunday. In the meantime, I ran a test off of a 12 volt battery direct to the individual (currently) exposed wires and confirmed brake lights and running lights work. Neither exterior (left rear/right front) loading lights work, but confirmed the bulbs are good. The interior lights do not work as well. I'm guessing these are powered by the battery (dead as dead can be) located in the tack room. Is that correct? Also, there is a toggle switch located at the rear left (driver's side). What is this switch for? Thanks for any help. Bill
Is there a mini-battery on the trailer tongue?...If so, that would be your breakaway battery...
If not, then the dead battery inside the trailer must have served for the breakway battery
That rear switch could be for the interior lights...the other thing to check is to see if there was a load light wired up in the past over the rear doors...
https://cokluindir.com/wp-content/uploads/2018/02/wiring-diagram-trailer-wiring-diagram-6-pin-6-pin-trailer-plug-free-download.jpg
eldoradobill
Reg. Aug 2018
Posted 2018-08-05 8:33 AM (#171778 - in reply to #171776)
Thanks - I found a wiring diagram and it's clear the battery is only to power the break away.
The diagram shows the toggle, but I'm still at a loss as to its purpose. I'm guessing a one-stop-switch to kill all the lights. There are loading lights rear driver's side and front passenger's side and two lights in the trailer section, both with their own push button switches.
I won't know until this evening if they work. I know the bulbs are good. The replacement plug is supposed to show up later today.
