refrigerator problems
Last activity 2018-05-31 6:52 AM
4 replies, 5693 views
lopinbay
Reg. Jan 2013
Posted 2018-05-30 10:55 AM (#171630)
Subject: refrigerator problems
i now have a norcold n300 3 rv refrigerator, that runs on electric, gas, batterie, it never works right and i'm thinking of just putting in a electric refrigerator for which i very seldom use the gas part of it, any cons  of doing this, have any one had better luck with just a eletric frig running better, thanks
Steve-O
Reg. Mar 2016
Posted 2018-05-30 1:24 PM (#171631 - in reply to #171630)
Subject: RE: refrigerator problems
It is nice to be able to run the fridge on propane in my opinion.
One of my trailers I have a small electric ( house style ) refrigerator in and it works well.
A house style refrigerator uses refrigerant and a compressor,  RV style refrigerators work off of absorption ( no compressor )   they use the heat generated from the electric device or propane to heat and move the refrigerant.
It is vital for the absorbtion fridge to be level for it to work.  Are you keeping it level at all times while parked?
beeoerdog
Reg. Jan 2014
Posted 2018-05-30 1:55 PM (#171632 - in reply to #171630)
10010010010025
Before abandoning your Norcold ( a nice little fridge ) read the owners manual and follow directions. Problems are easily diagnosed using some online resources.
RustyScupper
Reg. Mar 2013
Posted 2018-05-30 4:22 PM (#171634 - in reply to #171630)
Also, without knowing the age of the fridge.  It is possible that the orfice is bad and it isn't burning efficiently therefore not cooling.  Can you see a clean blue flame?
cajunmuleman
Reg. Oct 2011
Posted 2018-05-31 6:52 AM (#171635 - in reply to #171630)
if refrigerator doesn't get cold enough try adding small fan blowing upward behind refrigeraor to remove the heat thru top and also making sure the vent is clear
