Mattress replacment
Last activity 2019-05-14 1:51 PM
5 replies, 6169 views
tim62988
Reg. Aug 2012
Posted 2018-02-15 6:06 PM (#171279)
Subject: Mattress replacment
 so been casually looking at upgrading to an LQ trailer
one thing i've been seeing on occasion is a wall between the bunk & everything else.   how the heck do you get the old mattress out and a new mattress in?  or are you stuck with the matress from factory?
beeoerdog
Reg. Jan 2014
Posted 2018-02-15 6:17 PM (#171280 - in reply to #171279)
Subject: RE: Mattress replacment
10010010010025
Mattress is very flexible....not like a box spring
cajunmuleman
Reg. Oct 2011
Posted 2018-02-16 5:01 AM (#171281 - in reply to #171279)
-Like was said you should be able to fold in half or kind of roll up the old one. If it is not good with a little imagination you can remove the old one. Our trailer is like you described with a sliding door closing off the bedroom area and we replaced ours with one like this--
https://www.amazon.com/gp/product/B00NX8G4LK/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
RustyScupper
Reg. Mar 2013
Posted 2018-02-16 8:59 AM (#171283 - in reply to #171279)
Easiest way is to take two pieces of rope with a loop thru the end.  One person at each end (head/foot), put the rope under the mattress and feed the end of the rope thru the loop.  Now roll the mattress like a burrito and tighten the rope as you go.  When you have it rolled as tight as you can tie off the rope.  Use the rope as a handle and use it to "walk" it out of the trailer.
If you buy a mattress for a trailer, they typically are shrink wrapped into a burrito shape.  Put in place, cut the shrink wrap and stand back.
tim62988
Reg. Aug 2012
Posted 2018-02-19 3:36 PM (#171306 - in reply to #171279)
thank you all for your thoughts:
i was thinking typical mattress with the coil springs, for some reason wasn't thinking of the foam ones, or hunting down a trailer specific one
Spin Doctor
Reg. Nov 2008
Posted 2019-05-14 1:51 PM (#172381 - in reply to #171279)
 If you replace a LQ mattress, be aware that a lot of LQ noises are very low clearance, and the factory mattress is a "low profile". IMO that is why most of them suck-as they are thin for more clearance. But when you put a "normal" mattress in a LQ, expect to lose 2-6" of head clearance.
