Trialer Tires
Last activity 2018-01-04 2:50 PM
4 replies, 6244 views
1tomanyhorses
Reg. Apr 2008
Posted 2018-01-02 2:34 PM (#171062)
Subject: Trialer Tires
 Wondering if anyone out there has an opinion as to the best tires to use on both horse trailer and other trailers. I understand there is a difference between running LT truck tires and specific trailer tires. there is a lot of talk on the other forums out there on dissapointed people getting little mileage out of there tires. I am looking to run 235/85/16 load range F (for the side wall flex). for my stock trailers and flat bed trailer. Called the manufacture about there suggestion and had none. actually they use a truck tire becuase the got a good deal on them. Any thoughts ?
DLR
Reg. Jul 2004
Posted 2018-01-03 6:03 AM (#171065 - in reply to #171062)
Subject: RE: Trialer Tires
 Just a couple of post back, read the post "Best affordable trailer tires".  Some good opinions.
horsey1
Reg. Dec 2004
Posted 2018-01-03 11:52 AM (#171066 - in reply to #171062)
I personally run a LT235/85R16 on everything I can. Load range E, or G. I've had trailers with the ST235/85R16 in a E or F rated for a lot of weight, and had issues. Replaced with a LT235/85R16 "E" that's only rated at 3,042# and ran the wheels off of the trailer. There seems to be more "fluff" in a LT tire's ratings, and maybe the ST are right there? Or maybe the hight and shifting cargo of a horse trailer overloads the ST's softer sidewalls? Or don't know. I do know I've been very happy with the LT
Posted 2018-01-03 2:38 PM (#171067 - in reply to #171062)
Whenever possible I always replace ST tires with LT's. Longer life spans, higher speed ratings, better durability and less UV damage. Very pleased with the changes
HOUSE
Reg. Oct 2008
Posted 2018-01-04 2:50 PM (#171076 - in reply to #171062)
I always use LT tires, the ST tires are such low quality and all made in China, I have had pretty good luck with coopers in a 16" tire, however my first choice is to upgrade to a 17" tire and wheel, the tires are a bit more expensive  than a quality 16" tirebut they last 2-3x's as long.  and they have far more weight capacity. my tires on my horse trailer are YOKOHAMA RY023 235/75R17.5 H BSW and they have a load rating of 6005 lbs per tire.  if you are pressed for space you can get it in a 215/75r17.5 that gives you 4800 lbs per tire.  Also that is one of the few tires that are 17.5 that are speed rated for 75 mph.
