Merhow wiring problem...HELP!
Last activity 2017-09-21 8:21 AM
4 replies, 6071 views
raffonel
Reg. Sep 2014
Posted 2017-09-19 2:39 PM (#170651)
Subject: Merhow wiring problem...HELP!
Blew a tire on the left side of my gooseneck LQ.  Two wires hanging, one green, one yellow.  According to the 7 pin schematic...the yellow should be for the left signal and green for the right...um...signals work, running lights do not and an auxillary compartment light above the tire wheelwell has to be replaced .  Emergency 4 ways also work. Which should go to the running lights???
beeoerdog
Reg. Jan 2014
Posted 2017-09-19 8:11 PM (#170656 - in reply to #170651)
Subject: RE: Merhow wiring problem...HELP!
10010010010025
Look for a junction box in the vicinity of where the wires were pulled loose. Colors of wires not necessarily what is on the schematic. Use a 12v test light to determine which wire is for the running lights.....turn on headlights and see which wire gets power
Posted 2017-09-20 2:41 AM (#170666 - in reply to #170651)
Checking with a continuity tester is the easiest...but you may check to see if your trailer might have been wired RV standard...
Black wire 12 volt power
Tail and running lights are green wire,
Yellow wire is Reverse lights
Brown wire is Right turn and stop
Red wire is Left turn and stop
Blue wire is brake controller output
White wire is ground
Check Trailer side 7 way on this site...
https://www.etrailer.com/faq-wiring.aspx
Edited by PaulChristenson 2017-09-20 2:42 AM
raffonel
Reg. Sep 2014
Posted 2017-09-21 6:59 AM (#170676 - in reply to #170651)
FIXED!!  Truck fuses blew when wiring got shredded!
Posted 2017-09-21 8:21 AM (#170678 - in reply to #170651)
Raffonel ... Thanks for closing the question. Too many folks ask for help and then disappear. We never get to know if our advice/guesses were correct for the next person.
