Unknown light switches
Last activity 2017-08-16 4:27 PM
11 replies, 6922 views
cgreenmyer
Reg. Aug 2017
Posted 2017-08-13 11:49 AM (#170373)
Subject: Unknown light switches
I just purchased a 2006 Silverlite. It has 2 switches that I can't figure out what they go to. The 1st is on the row of interior light switches. There's 3 on top and 2 on bottom. The top left one seems to not be hooked to anything, or at least I can't find it. The second switch is the outside load light switch. It's a 3 way switch, left turns on the load lights, center is off, and right is a mystery. Anyone have ideas?
beeoerdog
Reg. Jan 2014
Posted 2017-08-13 1:06 PM (#170374 - in reply to #170373)
Subject: RE: Unknown light switches
10010010010025
Lighted entry handle?
cgreenmyer
Reg. Aug 2017
Posted 2017-08-13 1:10 PM (#170375 - in reply to #170373)
It has one, but it's not that switch.
Edited by cgreenmyer 2017-08-13 1:11 PM
hgut
Posted 2017-08-13 2:59 PM (#170376 - in reply to #170373)
the outside 3 way switch could it also turn on a interior horse compartment light?
beeoerdog
Reg. Jan 2014
Posted 2017-08-13 3:08 PM (#170377 - in reply to #170376)
10010010010025
pop the switches out and verify that there is a wire attached to the terminal. Or wait until dark, turn everything on and see what doesn't work. Check all your 12v fuses as well.
72chevylonghorn
Reg. Aug 2017
Posted 2017-08-13 5:21 PM (#170378 - in reply to #170373)
I can't imagine anything that you wouldn't want on at the time as the interior horse compartment lights, that would warrant a "3 way switch" ( technically a single pole, double throw switch- common feed supplying 2 loads). I agree with the PP about pulling the switch to see if there is a third wire connected. If there is, it could be for future fans, perhaps?
Check to see if the interior switch is an over ride for the light above the range of above the sink. I know my sundowner has one that, if the switches aren't turned on at the light itself, you'd never know there's a primary switch. Just a thought....
cgreenmyer
Reg. Aug 2017
Posted 2017-08-13 7:31 PM (#170379 - in reply to #170376)
The interior lights are on there own switch. All of the switches are wired in.
Edited by cgreenmyer 2017-08-13 7:33 PM
RTSmith
Posted 2017-08-14 10:00 AM (#170380 - in reply to #170373)
the 3 way switch- in the "unknown" position, check to see if it allows the load lights to act as reverse lights. Silverlite did this a lot. Factory 7 way plugs will typically have the center pin as reverse lights. But many that were installed after the fact for a GN will not, as GN don't usually have back up lights.
beeoerdog
Reg. Jan 2014
Posted 2017-08-14 7:26 PM (#170383 - in reply to #170373)
10010010010025
You could also acquire a "toner" and follow the wires without having to take off any panels.
Jeepplr
Reg. Oct 2007
Posted 2017-08-15 7:55 PM (#170387 - in reply to #170373)
Could it be lights under the gooseneck or baggage compartment lighting?
Don't feel alone, my house has 3 of those switches. They all had power when I bought the house.
Posted 2017-08-16 3:59 PM (#170392 - in reply to #170373)
So OP have you determined if the 3rd position is any of the guesses?...especially implementing the load lights as backup lights...:)
Edited by PaulChristenson 2017-08-16 4:01 PM
akinstrailers
Reg. Apr 2009
Posted 2017-08-16 4:27 PM (#170393 - in reply to #170373)
We've had some Silverlite's where one of those switches runs the radio and the other will run the exterior speakers.  They also used to wire in a switch that would turn off the outlet to the microwave.
