Can white skin aluminum be painted
Last activity 2017-08-15 11:19 AM
4 replies, 9984 views
cjjet
Reg. Sep 2010
Posted 2017-07-22 11:52 AM (#170313)
Subject: Can white skin aluminum be painted
 I'm looking at purchasing an older aluminum trailer that the  white skin aluminum is clauky, faded, and wearing off on most of the trailer.  Can the white skin be painted?  If so, will it last and is it expensive to have it done?  What the process to have it painted?  Is it hard to find someone that can do this work?
Posted 2017-07-23 12:05 AM (#170316 - in reply to #170313)
Subject: RE: Can white skin aluminum be painted
You could try Everbrite...
https://www.everbritecoatings.com/how_to_aluminum.html
Posted 2017-07-23 10:44 AM (#170318 - in reply to #170316)
The finish can be repainted . The original metal was most likely purchased by the trailer manufacturer in bulk, and prepainted during roll coating. That paint apparenltly has suffered UV damage and failed.
?All the original paint will have to be removed if loose and powdered, and the metal's surfaces properly prepared before any respraying  can be started. Insufficient metal prep is the main reason why recoating aluminum can result in failures. This is true of body paints or even floor  covering issues.
?Today, because aluminum is readily used in automotive, marine and aircraft constructions, there are many commercially available products that can be used to recoat your trailer. In many cases they will be superior to the original coatings of older trailers in durability, gloss and UV protection.
?Properly respraying a trailer can beome an expensive proposition, because of the labour involved, the cost of materials and the pricing of professionals. It can be a DIY project for just the cost of materials..
cjjet
Reg. Sep 2010
Posted 2017-07-24 7:26 AM (#170321 - in reply to #170313)
Thank you for the information.  This is very helpful.
bigskyfarm
Reg. Oct 2004
Posted 2017-08-15 11:19 AM (#170384 - in reply to #170321)
?I am in GA as well and would like to know if you find someone local to paint a trailer. I would like to have my Sooner LQ painted.   email is carla @ bigskyfarm.com - spaces removed.
