Trailer Jack Replacement
Last activity 2017-07-23 12:12 AM
2 replies, 5673 views
Lazy M
Reg. Feb 2005
Posted 2017-07-21 10:13 PM (#170310)
Subject: Trailer Jack Replacement
 Hi,
I have just pruchased a "new" to me 2002 Elite, 2 horse, 20' on floor with full living quarters.   This trailer has a manual 2 speed jack which only works on the high side.    Cranks really heavy, I have been told that jacks only last about 10 years and I wonder if it needs replaced as it seems to not working right.   So going off of that,  I feel like I should have a new jack put on.   I was thinking of getting an electric one, the hydraulic ones are just too much money, but I have been told that the electric one won't hold up and that I would be wasting my money,  Is this true?      Am I better off just getting another 2 stage jack?   Trailer has one battery, is one battery going to be sufficient to run the electric jack?  Trailer weighs 8,300 lbs empty.
Thanks
Joan
RTSmith
Posted 2017-07-22 7:58 AM (#170311 - in reply to #170310)
Subject: RE: Trailer Jack Replacement
Yes- 1 battery is generally just fine. And yes- the electric motor on a crank jack works fine and for a long time, just a touch slower than a hydraulic.
But- the electric motor that goes on a 2sp has to have the jack locked in low, then the motor is fitted. So there's no point to replace the 2sp and then put the motor on- just install the hydraulic. Probably same price in the end, and you'll be happy.
Posted 2017-07-23 12:12 AM (#170317 - in reply to #170310)
Lazy M - 2017-07-22 1:13 AM  Hi,
Thanks
Joan
 Well, If you don't grease it that is probably true...
If your jack is a Bulldog...here is the video on replacing the gears...:)
https://www.youtube.com/watch?v=GHcbEWyVzOc
