Aluminum planks supplier?
Last activity 2017-09-12 10:15 PM
4 replies, 7152 views
jbv
Reg. Jun 2017
Posted 2017-06-24 11:46 AM (#170123)
Subject: Aluminum planks supplier?
I have been trying to locate a supplier of aluminum planks. I would prefer to replace a few sections of my planking which are pitted versus sheeting over the floor. Trailer is a 2000 Sooner Revolution with aluminum floors. Planks are 10.25" (w) x .5" (d) approximately, lengths vary and are interlocking edges. Sooner manufacturer has no information or help.
If you have any sources I would really appreciate it.
wildphoenix
Reg. Oct 2009
Posted 2017-06-24 2:30 PM (#170124 - in reply to #170123)
Subject: RE: Aluminum planks supplier?
 I think Sooner, Featherlight and Exiss are all made by Universal now and if I understand it right, a trailer as old as your may not have a compatible design for the planks they currently use now. I just went thru this with my trailer. Even finding a suitable flooring replacement today with aluminum is going to be super expensive not because of materials, but the labor involved in repair.
jbv
Reg. Jun 2017
Posted 2017-06-26 6:01 PM (#170152 - in reply to #170124)
Thanks for the reply. I have investigated several planks but none seem compatible. Just have a few spots to repair and it appears like my best option is to sandblast current floor, seal/paint, cover with aluminum sheets 3/16. I will have to screw the mats down so they won't slide.
Would like to hear options.
huntseat
Posted 2017-09-12 9:05 AM (#170612 - in reply to #170152)
1000500100100100100252525
I think your Al sheeting idea is your cheapest route but can't you find Al diamond plate?
I know trailers that came from the factory with sheet flooring and the mats don't slide, but they are wall to wall and hold each other in place.
Posted 2017-09-12 10:15 PM (#170617 - in reply to #170123)
What kind of damage do the planks have ? A few holes on the surface? The advantage planks have over sheet metal, is the strength is in the vertical ribs. Think of a metal grate...
If the ribs are not damaged, then the surface holes are merely cosmetic. I would use an epoxy putty to fill the holes.
Over sheeting the floor creates voids for urine to get into that you can't flush away.
