Any issues with Ram 2500 w/ RamBox towing gooseneck?
Last activity 2017-07-11 10:46 PM
4 replies, 9587 views
ChopRod
Reg. Oct 2013
Posted 2017-06-13 12:35 AM (#170056)
Subject: Any issues with Ram 2500 w/ RamBox towing gooseneck?
Hi- anyone towing a gooseneck LQ trailer with a Dodge Ram equipped with the RamBox in-bed cargo boxes? Bed is narrower on the inside but not taller unless RamBox lids are open which wouldn't be when trailering, of course. Looking at a used Ram 2500 4X4 6.4L and know they are higher than my previous generation 2500- which I don't care for. It is also a shortbed and no issues with it. Travel around 1-2k mi per year going to various horse camps for trail riding.
Any input is appreciated. Thx!
mlfisher40
Posted 2017-06-14 3:10 PM (#170059 - in reply to #170056)
Subject: RE: Any issues with Ram 2500 w/ RamBox towing gooseneck?
I know you can't get a factory gooseneck hitch prep package wtih the Rambox. I believe it's because the puck system is too wide to accomodate the box. So, as long you can find an aftermarket hitch, i.e. B&W, I think you would be ok. Pulling a gooseneck with a shortbed on the other hand.
ChopRod
Reg. Oct 2013
Posted 2017-06-14 9:24 PM (#170062 - in reply to #170056)
 Thanks for the response. Also found that the RamBox drops the towing capacity down several hundred pounds. Nixted the idea- just too small a space anyways. Previous truck was a Ram quadcab short bed. Never had any issues towing. Tapered nose on LQ trailer that has a California king-sized bed in the goose.  7' wide helps too. An 8' wide square nosed unit- maybe not so good.
huntseat
Posted 2017-06-16 9:39 AM (#170074 - in reply to #170056)
1000500100100100100252525
I'd worry about how you were gonna get to the tools in the toolboxes in the event of an emergency.  Glad you nixed the idea.
ChopRod
Reg. Oct 2013
Posted 2017-07-11 10:46 PM (#170253 - in reply to #170056)
 Gave up buying new havng acquired an 04 Ram 3500 dually with 5.9, 4:10 gears and only 72k mi. Way under book from private seller. Problem solved. Well, are problems ever really solved with no matter what you buy...... lol
