LED Bulbs- Inside and Out
Last activity 2017-10-30 10:27 PM
8 replies, 7112 views
Cutter1999
Reg. Jan 2017
Posted 2017-04-18 11:56 PM (#169790)
Subject: LED Bulbs- Inside and Out
I am thinking about replacing the incandescent bulbs with LED bulbs both inside and out. From what I have read online I would not have to swap out fixtures or light assemblies themselves- just the bulbs. Anyone else do this? Positive or negative experiences?
There are a couple things I would like to achieve with this switch. Inside, I would like the light to be brighter as well as the bulbs cooler. Outside, I am interested in brightness. I have one marker light on a fender that I swear is always out when I am in the driver's seat, but it is actually on and just not very bright.
Thanks for your help!
cajunmuleman
Reg. Oct 2011
Posted 2017-04-19 5:24 AM (#169791 - in reply to #169790)
Subject: RE: LED Bulbs- Inside and Out
I had it done and like it for the same reasons you stated. In the horse area I had to change the fixtures because the lenses were "foggy".
TS351
Reg. Apr 2014
Posted 2017-04-19 8:05 AM (#169794 - in reply to #169790)
I swapped all my inside ones out and went from drawing 23 amps to 3 amps with main lights on, really saves batteries. Got them all on E-bay pretty cheap just search for type of bulb base you have, G4, 1156, etc. There are different brightnesses so make sure you get what you want. I had LEDs on outside already but you may have to swap fixtures outside as most are sealed units.
hgut
Posted 2017-04-20 3:15 PM (#169808 - in reply to #169790)
Yes I changed all of ours to led , we really like them, we got them on ebay
peter
Reg. Aug 2016
Posted 2017-04-25 9:07 PM (#169822 - in reply to #169790)
Yes I've done it, just swap out bulbs.
The lights will be brighter and will draw less current from your batteries.
AZgrulla
Reg. Jan 2009
Posted 2017-04-29 7:58 AM (#169827 - in reply to #169790)
does anyone have the link to the ebay store for the replacement lights?
Thank you!!!
cajunmuleman
Reg. Oct 2011
Posted 2017-04-29 9:42 PM (#169834 - in reply to #169790)
?There are many different sellers of LED bulbs, Just put in your old bulb number and "LED". Is this what you are asking?
etrailer John
Reg. Nov 2016
Posted 2017-10-30 11:03 AM (#170776 - in reply to #169790)
There are many good reasons to swap out the existing incandescent bulbs for LED's- less power draw, more brightness and longer life.
In many cases you can simply swap out the bulb, unless the lamp is sealed in which case you'd need to replace the lamp itself.
For more information about LED lamps and available replacements use the provided link:
https://www.etrailer.com/expert-170.html
hitmis
Reg. Oct 2017
Posted 2017-10-30 10:27 PM (#170783 - in reply to #169790)
I put all LED in inside on my 2017 EXISS Works good . Had to change wiering in lamp fixturs so that the positive lead goes to center post of lamp you will love it got Amision
