Bigfoot Trailer Jack
Last activity 2017-03-07 11:07 PM
3 replies, 5173 views
tamianderson59
Reg. Dec 2011
Posted 2017-03-07 9:22 AM (#169501)
Subject: Bigfoot Trailer Jack
 My LQ trailer has a Bigfoot one point jack. It started acting sluggishly and now has stopped working completely. I am at a loss as to where even start troubleshooting this.
kooner
Reg. Jun 2011
Posted 2017-03-07 10:42 AM (#169502 - in reply to #169501)
Subject: RE: Bigfoot Trailer Jack
for a start make sure battery is charged,  check all electrical connections and last but not least the hyd. oil..  if none of this helps I would re post with ideas as to what it does and does not do.
huntseat
Posted 2017-03-07 6:33 PM (#169512 - in reply to #169501)
1000500100100100100252525
Agree, check battery.  They can drain a battery in about 30 lifts so just know that you'll need a battery trickle charger to keep it topped off.
Posted 2017-03-07 11:07 PM (#169514 - in reply to #169501)
tamianderson59 - 2017-03-07 12:22 PM  My LQ trailer has a Bigfoot one point jack. It started acting sluggishly and now has stopped working completely. I am at a loss as to where even start troubleshooting this.
“I push the switch but nothing happens”
Check both positive & negative 12V connections.
Check for full charge of battery.
Check that tank assembly has proper ground.
Check wiring connections.
http://nebula.wsimg.com/418942516e4c3bcf2ce00590e91fe9f4?AccessKeyId=C482E3B4FA9C11D5C622&disposition=0&alloworigin=1
