Fender for Trail-Et
Last activity 2017-02-07 7:39 AM
3 replies, 5404 views
syndiego
Reg. Jun 2012
Posted 2017-02-06 2:42 PM (#169292)
Subject: Fender for Trail-Et
I had a blow-out on my Trail-et, and the fender is bent up.  It's still functional, just cosmetic, but I would like to fix it.
Can the fender be repaired, or does it need to be replaced?  Where would I get a replacement, considering Trail-Et is no longer in business?
Thanks!
Cindy
Cutter1999
Reg. Jan 2017
Posted 2017-02-06 4:18 PM (#169294 - in reply to #169292)
Subject: RE: Fender for Trail-Et
You can buy aftermarket fenders from some of the online trailer places. Another option might be to contact Hawk, as their trailers are very similar to a Trail-Et.
Posted 2017-02-06 7:20 PM (#169296 - in reply to #169292)
http://horsetrailerworld.com/forum/forums/thread-view.asp?tid=2801
Kay
Posted 2017-02-07 7:39 AM (#169300 - in reply to #169294)
50025
The Hawk fenders are fiberglass.  A replacement aluminum fender should not behard to find.  Measure the depth from the sidewall of the trailer to the edge of the fender radius, and measure across the bottom for length.  You will want a tandem teardrop if the jargon confuses you.  You can lengthen or shorten the length by an inch or so when you install the fender.
