Floor corrosion question
Last activity 2017-02-07 11:47 PM
3 replies, 5260 views
aqhaktberry3
Reg. Feb 2017
Posted 2017-02-05 6:37 PM (#169285)
Subject: Floor corrosion question
Hello everyone!
I have a 1999 featherlite trailer that I recently purchased and found 3 small pitting holes. I would like to repare to reline the floor. I plan to use epoxy to fill the three holes.
Do I HAVE to etch the floor with muriatic acid or can I sand the areas where the original lining has worn and just skip straight to the hurculiner? I have photos but not sure how to attach...
How do you handle the drainage holes that are intentional in the aluminum floor-- how to you not put the hurculiner in the holes/ keep the holes and not seal them?
Edited by aqhaktberry3 2017-02-05 7:00 PM
cajunmuleman
Reg. Oct 2011
Posted 2017-02-05 7:06 PM (#169286 - in reply to #169285)
Subject: RE: Floor corrosion question
This is a thread that goes way back with plenty of discussion. Gard is the expert on this and has helped many people -http://www.horsetrailerworld.com/forum/forums/thread-view.asp?tid=12471&start=1---
aqhaktberry3
Reg. Feb 2017
Posted 2017-02-05 7:46 PM (#169287 - in reply to #169285)
Thanks, I read it but am wondering if I have to do the acid
Posted 2017-02-07 11:47 PM (#169305 - in reply to #169287)
If the floor is already coated with a bed liner material, just the damaged areas can be repaired. Applying the Muriatic acid cleans  the bare metal and etches the metal so the liner material has a better purchase. The metal can also be sanded, which will also clean and prepare the metal for surfacing. Sanding will work well for smaller areas, the acid on larger ones.
?The holes that are to be repaired should be drilled out or sanded to provide fresh metal edges to the epoxy. If you then use a counter sink bit on the holes, they will hold the epoxy material much better.
After the floor is  recoated, the drain holes can be redrilled, opening them to their original diameters.
