Smoke alarm goes off when furnace is on
Last activity 2017-01-05 2:59 PM
2 replies, 4884 views
Hillview
Posted 2017-01-04 8:08 PM (#169070)
Subject: Smoke alarm goes off when furnace is on
 Hi - I have a new Lakota LQ.  I was prepping it tonight for our first show this weekend.   I wanted to make sure the furnace was working properly because it going to be very cold this weekend.   After a few minutes, the smoke alarm went off.  I opened the door and cleared the air and it went off.   Shut the down and 10 minutes later it went off again.  Any ideas why?   I didn't think the smoke alarm should go off unless there was actual smoke, which there was not.  The carbon detector did not go off - just the smoke alarm.
Thanks for your help in advance.
beeoerdog
Reg. Jan 2014
Posted 2017-01-04 9:22 PM (#169071 - in reply to #169070)
Subject: RE: Smoke alarm goes off when furnace is on
10010010010025
Probably because it is a new unit......oils on the metals from the mfg. process remain until burned off....usually only takes 5-10 minutes before it clears up. If it continues, take it back to dealer for inspection.
akinstrailers
Reg. Apr 2009
Posted 2017-01-05 2:59 PM (#169072 - in reply to #169070)
I agree with the above poster.  We normally run the furnaces for an hour as part of our PDI process to clear anything through the lines.  If it persists you probably have a faulty smoke detector.  Thad
