Trailer mats
Last activity 2017-01-14 9:04 AM
8 replies, 6910 views
Hillview
Posted 2016-12-29 2:34 PM (#169043)
Subject: Trailer mats
 Hi - I have a new Lakota slant load step-up.  The mats that came with it are flat with no ridges or any texture.  They can get slick pretty easily in wet weather or with moist poop.   I don't use shavings when hauling.  Is there anything I can do to create some traction so my horse doesn't slide when loading and unloading?
?Thanks!
kooner
Reg. Jun 2011
Posted 2016-12-30 7:54 AM (#169046 - in reply to #169043)
Subject: RE: Trailer mats
tractor supply has soft mats and they have alot more grip than alot of mats out there, but I would use shavings and it will help your problem alot .
Posted 2016-12-30 10:02 AM (#169048 - in reply to #169043)
Ditto the shavings. They will help with the traction and keeping the floor less wet.
Cutter1999
Reg. Jan 2017
Posted 2017-01-01 9:13 PM (#169053 - in reply to #169043)
Shavings are well worth it.
horsin around
Reg. Jun 2005
Posted 2017-01-09 5:23 PM (#169088 - in reply to #169043)
100100100
 I carry a can of cat litter or you could use sand too to put down on the floor over the wet spot.  I have a mule the does a flying leap in and if the floors slick and she slides, she doesn't want to go in.  Put some cat litter down and in she'll go.
Posted 2017-01-09 5:50 PM (#169089 - in reply to #169043)
Shavings will protect the life of the floor of your trailer
aceliberty
Reg. Sep 2011
Posted 2017-01-09 5:54 PM (#169090 - in reply to #169043)
10010010025
We "double mat" our trailers to reduce wear and tear. We cut down a stall mat (Rural King or such) cut to size for extra padding. I feel it also reduces the fatigue on long distance trips. In addition to shavings, we use pellets on the places where the horse will urinate depending on whether we're hauling a gelding or mare at the time. They are super absorbent. I've observed that our horses have slid on mats ribbed or otherwise depending on if they're wearing shoes, frigid temps or whatever. Even our gelding that is super slow in loading/unloading, slipped on a ribbed ramp mat. We're no experts, but have been putting the miles on since retirement in '03.
horsin around
Reg. Jun 2005
Posted 2017-01-09 8:35 PM (#169091 - in reply to #169088)
100100100
I do ditto everyone on using shavings.  On my long hauls I put heavy shavings downs and on my short 20 minutes away park I put a lighter layer.  I have a area within the first step in and that can get a little slick if one of my critters urinate in the tailers and it doesn't bother my horses but it does my mule so i put alittle cat litter down and it helps.
huntseat
Posted 2017-01-14 9:04 AM (#169114 - in reply to #169043)
1000500100100100100252525
I'm going to say use any bedding material you are comfortable with...I personally bed the floor of my trailer with hay.  The reason I use hay and not shavings is that I cut my own hay, so there is a good supply and I can rake it out in the yard and in two weeks it's gone.  Hay is also very absorbant and I have yet to find a critter that won't happily load into a hay floored trailer.  (I haul horses/cattle/llamas/pigs/etc.)  You can pull your mats and have WERM flooring installed which is anti-slip.  Mats are not meant to be used naked, they need to have some bedding material over them to absorb the animal waste.  You may find that your horse has been holding their urine because they can't pee in the trailer where it will splash back up off the mats.  Many horses will only urinate on a properly bedded floor.  Make your trailer feel like home and bed it down!
