leveling
Last activity 2016-09-21 7:23 AM
3 replies, 5242 views
Dalet
Reg. Sep 2016
Posted 2016-09-19 12:59 PM (#168404)
Subject: leveling
I've got a 3 horse slant load LQ. Has anyone tried to install leveling jacks on theirs? What do you use when offgrid camping. blocks and....
flummoxed
Reg. Jun 2007
Posted 2016-09-20 6:38 AM (#168409 - in reply to #168404)
Subject: RE: leveling
The easiest leveling system I have found are Andersen levelers https://www.andersenhitches.com/Products/3604--camper-leveler.aspx
It takes me only a few minutes to level my 3H LQ. using them.
Dalet
Reg. Sep 2016
Posted 2016-09-20 2:55 PM (#168412 - in reply to #168404)
I didn't know about those. Are you supposed to use one per wheel?
flummoxed
Reg. Jun 2007
Posted 2016-09-21 7:23 AM (#168419 - in reply to #168404)
 You will need two, which will be used on one side of the trailer.
Depending on the spacing of your axles, you may have to cut a little off of the "tapered" end. Instructions are included with the levelers of how to do this. I had to cut them to fit my trailer and it was so easy to do.
As an aside, the prmary reason for leveling a trailer is so the refigerator works properly. The piece of advice I was given was to "level the refrigerator, not the trailer."  You can buy a small level called a torpedo level, which are cheap. They're only a few bucks at stores like Walmart. Put it on a shelf in the fridge and use it to level your trailer. I have found that using those RV levels that are placed on the outside of the trailer don't necessarily level the refirgerator.
