Another brake question. P3 shorted output error.
Last activity 2016-09-12 8:54 PM
4 replies, 4309 views
Wray
Reg. Jul 2012
Posted 2016-09-11 7:07 PM (#168363)
Subject: Another brake question. P3 shorted output error.
 I decided to replace the entire brakes on my 03 Exiss and sourced the brakes from Etrailer. Everything went smoothly throughout and When I got it all back together I started getting a shorted output alarm on the P3. I was careful on the install and taped up the crush butt connectors i used. I'm getting 7 ohms at the brake wire at the plug to ground which should be reading all the magnets in parallel if im undrestanding the brake right. Is there a good way to troubleshoot this? I'm planning on cutting them all loose one at a time and insulate the loose wires unitl i have them all loose if i have to take it  that far. I'm new to brakes and the magnets shouldn't have been polarity sensitive should they?  I hope yall can straighten me out this week. Thanks, Tim
*the brakes were working fine before i changed them.... they were worn was why i changed.
beeoerdog
Reg. Jan 2014
Posted 2016-09-11 7:44 PM (#168364 - in reply to #168363)
Subject: RE: Another brake question. P3 shorted output error.
10010010010025
Total resistance should be closer to 1 for all four magnets in parallel.
(http://www.1728.org/resistrs.htm) Check your ground connection before undoing all the brake magnet connections.
Wray
Reg. Jul 2012
Posted 2016-09-11 8:18 PM (#168365 - in reply to #168363)
Thanks B, I'll check into that tomorrow.
Guest
Reg. Dec 1899
Posted 2016-09-12 8:16 PM (#168375 - in reply to #168363)
Turns out I pinched a wire on one of the hub bolts for a direct short.
beeoerdog
Reg. Jan 2014
Posted 2016-09-12 8:54 PM (#168376 - in reply to #168363)
10010010010025
Good job...just like Sherlock Holmes!!!!
