power coverter
Last activity 2016-08-17 6:01 PM
8 replies, 5154 views
shearer67
Reg. Aug 2016
Posted 2016-08-16 10:03 PM (#168047)
Subject: power coverter
Any idea where they hid the power converter on my 03 elite 3h GN LQ. I have looked behind every panel ,door, the radio,fuse panel compartment ,still cant find it.
beeoerdog
Reg. Jan 2014
Posted 2016-08-16 10:07 PM (#168048 - in reply to #168047)
Subject: RE: power coverter
10010010010025
Look outside the trailer where the shore plug wire is stored....should be just inside from there....under a seat???
shearer67
Reg. Aug 2016
Posted 2016-08-16 10:19 PM (#168049 - in reply to #168047)
Its not under seat ,shore plug coils up under furnace ,no easy way to get under there .I may try my little mirror on a stick tomorrow with a flashlight to look around under there. Would have to remove wardrobe floor and furnace to get at it if thats where its hiding.
beeoerdog
Reg. Jan 2014
Posted 2016-08-16 11:08 PM (#168050 - in reply to #168047)
10010010010025
OK....unit should be readily accessible. Pull cord all the way out and look through the opening....also look for any panels held in place with screws.
Tx. Vaquero
Reg. Dec 1899
Posted 2016-08-17 9:51 AM (#168055 - in reply to #168047)
look behind your breaker/ fuse panel
Guest
Reg. Dec 1899
Posted 2016-08-17 10:21 AM (#168056 - in reply to #168047)
breaker fuse panel compartment was the first place I looked ,thats where I would have put it plenty of room in there for it and would have been easier wiring.
Tx. Vaquero
Reg. Dec 1899
Posted 2016-08-17 2:04 PM (#168060 - in reply to #168056)
Mine makes a little humming sound. Make you can track that sucker down by sound.
Guest
Reg. Dec 1899
Posted 2016-08-17 5:55 PM (#168066 - in reply to #168047)
Found it with mirror and light , its behind furnace on wall above door for shore plug. The only way to get to it is remove trim in wardrobe then wardrobe floor .Not the best spot,would have made more sense to put it in breaker compartment.Thanks for all the help.
beeoerdog
Reg. Jan 2014
Posted 2016-08-17 6:01 PM (#168067 - in reply to #168047)
10010010010025
