Faucet
Last activity 2016-08-04 2:34 AM
3 replies, 4575 views
peter
Reg. Aug 2016
Posted 2016-08-02 11:26 PM (#167900)
Subject: Faucet
I had plastic threaded faucet, and wife broke the knob, so off I go and get a brass threaded faucet, but I just cant get it to seal. I'm thinking it needs to be a plastic thread faucet in order for it to work correctly?
I was able to successfully upgrade the outdoor spotlights to LED lights and they're worth every penny.
Posted 2016-08-03 10:58 PM (#167914 - in reply to #167900)
Subject: RE: Faucet
First ... are the threads the same ? There are straight threads and tapered pipe threads. A straight thread fixture requires a rubber washer to seal. A tapered pipe thread requires a thread sealant ? Use either Teflon tape or paste.
peter
Reg. Aug 2016
Posted 2016-08-04 1:49 AM (#167917 - in reply to #167914)
Subject: RE: Faucet
hosspuller - 2016-08-03 10:58 PM
There are rubber washers on the inside of the plastic hose threads.
Posted 2016-08-04 2:34 AM (#167919 - in reply to #167917)
Subject: RE: Faucet
peter - 2016-08-04 4:49 AM
hosspuller - 2016-08-03 10:58 PM First ... are the threads the same ? There are straight threads and tapered pipe threads. A straight thread fixture requires a rubber washer to seal. A tapered pipe thread requires a thread sealant ? Use either Teflon tape or paste.
When working with fittings with straight threads, paste dope should always be used. Tape dope is too thick, and can actually prevent a good seal in straight thread joints. Paste dope will spread and be pushed out of the way, and will not prevent the threads from properly engaging.
