2 speed jack
Last activity 2016-07-06 5:52 AM
6 replies, 4440 views
4quartercirclesperfh
Reg. Jul 2014
Posted 2016-07-04 8:16 AM (#167448)
Subject: 2 speed jack
So as the title says I'm looking at options for my 2spd jack. I'm just coming off of a back injury and cranking on my trailer isn't cutting it any more, I'd go hydrolic but my space is limited unless there's a solution to not having a huge tank. I'm looking at the magnum lift electric jack conversion any thoughts to those?
cajunmuleman
Reg. Oct 2011
Posted 2016-07-04 9:31 AM (#167449 - in reply to #167448)
Subject: RE: 2 speed jack
I have a hydraulic and don't have a big tank anywhere. My trailer is also a 1999 Silverlite three horse. It originally had two electric and I had the hydraulic added. We really like the floor plan
Reg. Jul 2014
Posted 2016-07-04 9:40 AM (#167451 - in reply to #167448)
Did you get the one lifted 7500 lbs? I can't imagine I'd need a 12000lb lift. I found a hydrolic one that's only 200 more than the electric add on
cajunmuleman
Reg. Oct 2011
Posted 2016-07-04 10:36 AM (#167452 - in reply to #167448)
I have the Quadra Bigfoot Single Point Jack. It is 12K lb. That's what the trailer dealer suggested. How long is your trailer?
Reg. Jul 2014
Posted 2016-07-04 10:49 AM (#167453 - in reply to #167448)
Right around 35ft,i think I may need the 12000lb jack
Posted 2016-07-04 7:33 PM (#167455 - in reply to #167448)
http://www.thebigfootleveler.com
huntseat
Posted 2016-07-06 5:52 AM (#167489 - in reply to #167448)
1000500100100100100252525
I had emergency back surgery in July, last year. I then custom designed my new trailer with all my new-to-me limitations including an Equalizer hydraulic jack. One battery box and that's it, the bonus is that now all my lights work so I can load all my supplies without having to be hooked-up. After using my new trailer only a handful of times we put one on my dad's 24' Featherlite stock for fathers day! He now swears it's the best part about hooking up! You will not regret adding this to your trailer, bonus if you can get a script for the jack from your doctor you can take it off your taxes as a medical expense.
