fuse box
Last activity 2016-06-26 7:42 PM
2 replies, 6365 views
lyn4lq
Reg. Jun 2016
Posted 2016-06-26 5:05 PM (#167397)
Subject: fuse box
We have a 1997 or 1998 Exiss Pacer 3 hours Slant load trailer. We are having trouble with the lights working in the horse area. Everything we've read suggests we check the fuse box. We've crawled all over and under this trailer and can't locate a fuse box? Suggestions??
kooner
Reg. Jun 2011
Posted 2016-06-26 7:03 PM (#167398 - in reply to #167397)
Subject: RE: fuse box
if it does not have an LQ it may not have a fuse box, have you checked the wiring with a tester? you may have a short or disconnected wire some where else.
lyn4lq
Reg. Jun 2016
Posted 2016-06-26 7:42 PM (#167399 - in reply to #167397)
it probably was sold as unfinished LQ. previous owners did bad finish. we've gutted and trying to refinish. I do think hubby found there is no fuse box, but found short, using his testers. Will have to retrofit a distribution center. Hopefully all the labor in JUST the electrical will be worth it in the long run....
