Can't unhitch gooseneck - bent pin?
Last activity 2016-06-14 12:07 PM
7 replies, 6772 views
Eventer71
Reg. Jun 2016
Posted 2016-06-13 9:28 PM (#167304)
Subject: Can't unhitch gooseneck - bent pin?
I think I damaged my gooseneck hitch this weekend. I didn't do the best job lining up the ball and receiver and didn't pay attention while lowering the trailer - I assumed that the hitch would slide on as the offset was not very much. It didn't slide, it slammed :( Will now not release even though the release pin is fully retracted. I have gone thru the motions start to finish a few times in hopes that the hitch would work free - it hasn't.I have an appt to bring it to a service place later this week but was wondering if any of you have any advice?
Posted 2016-06-14 12:03 AM (#167305 - in reply to #167304)
Subject: RE: Can't unhitch gooseneck - bent pin?
1000500100100100252525
try spraying a free up spray and see if that helps
Posted 2016-06-14 7:44 AM (#167312 - in reply to #167304)
Originally written by Eventer71 on 2016-06-13 12:28 AM
If the release pin is fully retracted...then take a board and manually move the bottom slide portion of the gooseneck hitch to the open position and then turn the crank until the hitch lifts clear
Eventer71
Reg. Jun 2016
Posted 2016-06-14 8:50 AM (#167313 - in reply to #167304)
I should have taken a picture of the hitch - I have an Air Safe hitch and it is not externally configured like a stock hitch where i can manually force the external part to move. The release pin is fully pulled out but the "clamp" around the ball will not open - why I think I broke or badly bent a pin? I sprayed on a lot of wd40 yesterday but I don't think it will come freewithout more force than I can apply.I have since called the hitch manufacturer and they suggested using a crowbar - I don't have one in my possession right now and I hesitate to do this on my own.I am bringing it to a service place tomorrow morning so as to avoid further damage or complications I can't get my self out of easily :)Thank you for the replies!!!
kooner
Reg. Jun 2011
Posted 2016-06-14 9:26 AM (#167314 - in reply to #167304)
does your hitch have the 2 air bags? if so I have one and I do not see how you could have really bend anything, when you pull your pin will it rotate to keep it in the open position? I would then put a crow bar on the flat plate and pry it outward.
Eventer71
Reg. Jun 2016
Posted 2016-06-14 10:15 AM (#167315 - in reply to #167304)
Yes, It has two airbags and yes the pin is fully out and rotated. Ok, I will pick up a bar today and give it a try.Thank you!I love the hitch and really hope I didn't damage it. When I have a resolution I'll let you know :)
kooner
Reg. Jun 2011
Posted 2016-06-14 11:42 AM (#167316 - in reply to #167304)
Eventer if you want to give me a call I will explain how the hitch locks, and how to take it apart. 719 371 4296
HOUSE
Reg. Oct 2008
Posted 2016-06-14 12:07 PM (#167317 - in reply to #167304)
Subject: RE: safty hitch system
If it is the type of hitch i am thinking of there is a cam that rotates down to allow the ball to clear, this cam is held in place with a roll pin, that can sheer off. this has happened to me with several of these type of latch, i had a turn over ball so i un latched the ball and jacked it up, then welded the cam to the handle.
