Trailer tires whats the best? 14 ply
Last activity 2016-04-05 7:04 PM
6 replies, 9988 views
compactcd
Reg. Jun 2007
Posted 2016-04-04 7:33 PM (#166649)
Subject: Trailer tires whats the best? 14 ply
We need new tires... 14 ply 235 85 R16 what is the best tires.... We have a living quarters trailer 3 horse aluminum 10 ft living quarter 8 ft wide... 10,000lbs
Terrye
Reg. Nov 2010
Posted 2016-04-05 11:06 AM (#166653 - in reply to #166649)
Subject: RE: Trailer tires whats the best? 14 ply
Goodyear G614 14 ply 235 85 16Terry
Spin Doctor
Reg. Nov 2008
Posted 2016-04-05 11:25 AM (#166654 - in reply to #166649)
Replace tire and rim with 19.5" "Boar Wheel" system. 19.5" tires run with less pressure, cooler, last forever, and the new/rim tire will cost the same as a Goodyear. The tread depth is 2x as much so they last 2x as long and next time when you replace, the tires will be 1/2 as much as you will already have the rims.
Good luck!
fergus
Reg. Mar 2016
Posted 2016-04-05 12:38 PM (#166655 - in reply to #166649)
Goodyears are more than likely the best tire out there in this size.However I got sick of paying almost a $1000. every few years because of weather cracked tires so I started buying Hankook 14ply tires and have had great luck with them at almost 1/2 the price...
Tx. Vaquero
Reg. Jun 2006
Posted 2016-04-05 1:35 PM (#166657 - in reply to #166649)
Subject: RE: Aluminum floor and Duplicolor: What is the latest advise with new?
+1 on the Hankooks. Lots of miles with heavy load, no problems.
HOUSE
Reg. Oct 2008
Posted 2016-04-05 5:37 PM (#166662 - in reply to #166649)
Subject: RE: safty hitch system
when you say 10k is that the rating or is that they actual trailer weight, because if you are in 7-8.5K actual weight I would stick with a Hankook or Yokohama LT tire, however if you are 9.5K or over then I would go with a 17.5 inch tire or even a 19.5 inch tire, anything not Chinese knock off tires in either of those rim sizes will last you along time.
mulerider01
Reg. Aug 2012
Posted 2016-04-05 7:04 PM (#166663 - in reply to #166649)
Hankook
