F350 Trailer power plug
Last activity 2016-03-30 5:14 PM
3 replies, 4233 views
rehinson
Reg. Jul 2015
Posted 2016-03-30 3:10 PM (#166619)
Subject: F350 Trailer power plug
I have a 2001 Sundowner that was serviced 3 months ago and pulled by a Silverado 2500HD with no power issues. I have a new 2016 F350 DRW... the exterior lights (Brake, Running) work, but the inside lights for LQ and stall area will only come on if you turn them on and off for a few time...then they may or may not stay on. Does ford have something different then chevy and Tundru-that I used to test light and work. Ford dealer said there is nothing wrong with the F350 plug. Any suggestions.
kooner
Reg. Jun 2011
Posted 2016-03-30 3:16 PM (#166620 - in reply to #166619)
Subject: RE: F350 Trailer power plug
sounds to me that you have a ground problem, this might help to try but take a set of jumper cables if you have them and hook it to the truck and also the trailer and see if that helps.
RTSmith
Posted 2016-03-30 4:34 PM (#166621 - in reply to #166619)
The Ford battery power pin in the 7 pin is only hot with the key in the run position.
beeoerdog
Reg. Jan 2014
Posted 2016-03-30 5:14 PM (#166622 - in reply to #166619)
10010010010025
Shouldn't have anything to do with the truck. Those lights should operate with the house battery. Clean all battery connections including the ground to trailer frame. Switches could be giving out as well
