LQ power converter
Last activity 2016-02-07 9:47 PM
9 replies, 5013 views
Ncatanz
Reg. Jun 2008
Posted 2016-01-25 8:48 AM (#165937)
Subject: LQ power converter
Our WFCO power converter in our RV has no DC output, checked all fuses and I just ordered a new converter. We use our LQ regularly and often for over 5 years. How long do these converters normally last?
kooner
Reg. Jun 2011
Posted 2016-01-25 9:23 AM (#165938 - in reply to #165937)
Subject: RE: LQ power converter
ours is 10 years old and stays plugged in most of the time and it still works OK.
cajunmuleman
Reg. Oct 2011
Posted 2016-01-25 12:58 PM (#165942 - in reply to #165937)
I have a 1999 that also stays plugged in the majority of the time and still is fine
Posted 2016-01-25 6:24 PM (#165943 - in reply to #165937)
Did you recently replace your batteries?...If so, make sure you didn't install them backwards
Posted 2016-01-25 6:38 PM (#165944 - in reply to #165937)
Just to confirm...You have checked the 12VDC FUSES on the back of the WFCO unit
Ncatanz
Reg. Jun 2008
Posted 2016-01-26 6:43 AM (#165951 - in reply to #165937)
Paul,Yes, thanks, I checked all the DC fuses visually and even ohmed them out to confirm that they were good which they were. I did install new batteries lately but the converter was not working before the new batteries. I understand that if the batteries were installed backwards, these fuses would definitely blow which they did not. WFCO website has a good flow chart which I followed to determine that the converter was bad. I was just wondering what is the normal life expectancy of a converter and if there is anything that chews them up like running on a small generator ?
Ncatanz
Reg. Jun 2008
Posted 2016-02-06 5:01 PM (#166030 - in reply to #165937)
FYI, I replaced the converter and every thing is working fine now. Batteries charge up as they should.
cajunmuleman
Reg. Oct 2011
Posted 2016-02-06 5:07 PM (#166031 - in reply to #165937)
Congratulations. It's always nice when you can fix it yourself
Ncatanz
Reg. Jun 2008
Posted 2016-02-06 6:38 PM (#166032 - in reply to #165937)
Yeah, it was not too difficult other than working in 20 degree weather :) brrrr
bjhouten
Posted 2016-02-07 9:47 PM (#166041 - in reply to #165937)
5002525
My trailer is a 2007 and I just replaced my inverter this week. Glad it was easy to do!
