Led trailer clearance lights?
Last activity 2015-12-15 4:44 PM
9 replies, 5732 views
LSurb
Reg. Nov 2015
Posted 2015-12-12 11:35 AM (#165547)
Subject: Led trailer clearance lights?
I am needing new clearance lights and I have narrowed it down to two options. I do not know much about lights but these are the right size and they seem bright. Which one would be best for my trailer. I have a 10 ft 2 horse straight load.
First option:
http://www.ebay.com/itm/111438527747
http://www.ebay.com/itm/111530641921
Or
Second option:
http://www.ebay.com/itm/361243826691
huntseat
Posted 2015-12-12 12:12 PM (#165549 - in reply to #165547)
Subject: RE: Led trailer clearance lights?
1000500100100100100252525
Most trailer manufacturers put clearance lights as amber (yellow) on the front and along the sides but the final side light and rear lights are red. Then I'd get whatever you like the best and you might order an extra of each color. By the time things break you won't find parts anymore...my seals were always the first to go. However you will find that the LEDs are superior in both being seen from a distance and longevity of life.
LSurb
Reg. Nov 2015
Posted 2015-12-12 12:44 PM (#165551 - in reply to #165547)
But which of the lights would be the best?
huntseat
Posted 2015-12-12 12:49 PM (#165552 - in reply to #165547)
Pick the one with the better plastic, better seal and brighter lumen rating if possible in the limited info they provide.
Posted 2015-12-12 3:21 PM (#165554 - in reply to #165551)
Originally written by LSurb on 2015-12-12 3:44 PM
Buy from a fixed site like etrailer.com where you can return something if necessary or get followup support...ebay is fine if you know exactly what you want and have no expectation of returning anything...:(
Posted 2015-12-12 4:21 PM (#165555 - in reply to #165547)
The second option has a metal base instead of plastic, has a weather seal between the base and lens and is advertised as weather proof, and has more diodes per lamp than the first. I would say the second choice would give you a longer lasting and brighter installation.
LSurb
Reg. Nov 2015
Posted 2015-12-12 7:01 PM (#165557 - in reply to #165547)
I found both of those lights on etrailer.com they are just cheaper going through ebay. Also I didnt know if the diodes made a difference until I saw the videos of the lights on etrailer and the second ones are about 50x brighter than the first.
Posted 2015-12-12 10:32 PM (#165560 - in reply to #165547)
1000500100100100252525
I like the second ones
mingiz
Reg. Jul 2004
Posted 2015-12-13 8:03 AM (#165562 - in reply to #165547)
The brighter the better!!
HOUSE
Reg. Oct 2008
Posted 2015-12-15 4:44 PM (#165576 - in reply to #165547)
After having installed a bunch of different types of lights, i much prefer the kind where you screw through the cover rather than have the cover snap on over the top like you showed. like this onehttp://www.etrailer.com/Trailer-Lights/Optronics/MCL49AB.html
