RV Pump Converter Winterizing Kit
Last activity 2015-08-19 2:11 PM
5 replies, 4988 views
4quartercirclesperfh
Reg. Jul 2014
Posted 2015-08-18 6:21 PM (#164490)
Subject: RV Pump Converter Winterizing Kit
I am adding some goodies to our living quarters to make winterizing easier, I have the sureflo pump with the external strainer. I want to add the siphon to not fill the holding tank with antifreeze, but with the strainer I cannot install the three way valve and stuff. Can I just loose the strainer? Or can I install the valve some were else?
beeoerdog
Reg. Jan 2014
Posted 2015-08-18 6:35 PM (#164491 - in reply to #164490)
Subject: winterize
10010010010025
The valve can go anywhere between the pump and the fresh water holding tank
Reg. Jul 2014
Posted 2015-08-18 6:40 PM (#164492 - in reply to #164490)
Subject: RE: RV Pump Converter Winterizing Kit
You wouldn't happen to know what size the water lines are would you seems to be pretty standard rv lines,i may get some shark bite fittings and cut the line mid way back and two female ends and wala no more filling the freash water tank with rv antifreeze and taking months to get the taste out.
beeoerdog
Reg. Jan 2014
Posted 2015-08-18 7:09 PM (#164493 - in reply to #164490)
Subject: winterize
10010010010025
sorry, don't know....take a small piece to an rv store for proper fittings....the hardware store tubing is different
Reg. Jul 2014
Posted 2015-08-19 2:01 PM (#164499 - in reply to #164490)
Thanks I got the proper shark bite fittings and got it all hooked back up and the install was painless. Now I'm having hard time getting any water or the pump to run. I have the valves in correctly both on the hot water and the main line from the tank, what are the odds I have a bad pump and only breaking prime to do this it surfaced? Or does purging the air take a little longer than I thought?
Reg. Jul 2014
Posted 2015-08-19 2:11 PM (#164500 - in reply to #164490)
HA! I hate to admit to this but alas I am,so I filled my tank after getting every thing put back together and some how my tank mist have had a air bubble because it was almost empty when I looked under the stairs! I'll go sit in the corner now.
Running MegaBBS ASP Forum Software
© 2002-2026 PD9 Software
