Buzzing noise in trailer
Last activity 2015-07-13 10:03 AM
3 replies, 4010 views
SuzieQ
Reg. Aug 2009
Posted 2015-07-13 7:07 AM (#164024)
Subject: Buzzing noise in trailer
I have an '02 gooseneck Featherlite that I pull with my Ram2500 diesel. Just recently, on two occasions when I've had the truck & trailer hooked up, I heard a buzzing noise near the horse compartment. It sounds like wasps buzz. When I disconnect the electric from the truck, the noise goes away. I replugged it, and no noise either. Can anyone suggest what might be happening? Is it a short or brakes issue? Is it dangerous? Thanks for your help.
beeoerdog
Reg. Jan 2014
Posted 2015-07-13 8:28 AM (#164027 - in reply to #164024)
Subject: brakes
10010010010025
Does your brake controller indicate any voltage going to brakes....maybe your slide switch is not completely off???
SuzieQ
Reg. Aug 2009
Posted 2015-07-13 9:26 AM (#164028 - in reply to #164024)
Subject: RE: Buzzing noise in trailer
Good suggestion, I'll check for that. The digital display on the brake controller often flashes and displays numbers even when it's not connected to the trailer.
beeoerdog
Reg. Jan 2014
Posted 2015-07-13 10:03 AM (#164030 - in reply to #164024)
Subject: RE: Sterling Coach OEM Marker Light Manufacturer
10010010010025
Shouldn't do that. It might be defective
